Thread: Lsx Void 3.0
  1. #2381
    Variable Bitrate TeamRSX's Avatar
    Nov 2007
    Ottawa, Ontario
    Quote Originally Posted by liquid_smoke View Post
    Cool.
    I dont have the hardware so im not sure if even need to bother with the converter. Its kind of odd though the converter is online, so for this all to work you also have to have an online connection?
    either way, im gonna pass on doing it tonite, ive been screwing with the timer **** all day and need a break. I prob need to read through that thread though and know of any issues etc before i add it in as default. Dont want to rush it as it seems it requires a few things.
    so ill post the update in a bit and work on the dsatx update as a separate update for those that have the hardware.
    I dont have my brainstem which connects to the dsatx power supply which connects to serial to test the converter.
    I wouldn't think you need to bother with the converter as this could be download anytime and configured accordingly and especially since you dont have the dsatx and brainstem to test i'm sure just adding the flash and skin would be great.
    Maybe someone else can confirm if you need an online connection for the converter. I wouldn't think so, but from what i was reading you may.
    I get my DSATX and brainstem early this week so i can test it then.
    No rush to add this, but would be great as a seperate update. Great job..
  2. #2382
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    3.301 update
    3.301 update
    this is a minor update.
    fixes:
    orb intergration embeding problems.
    movietimes intergration embeding problems.
    new idle screen for main menu.
    timer tweaks on the audio player, now when u have auto album art view on, it will return to list view on track change and then go back to album view after 15 sec.
    There is a slightly new splash screen with correct version number of skin.
    few small bug fixes.
    Things to note.
    I believe IDL commands are broken in RR if you have a directory list on the screen you are using the command, so unfortunately this also breaks the auto album art view on the audio player. So if you have auto album art view turned on, yet it never goes to the album art view on its own, this is why and hopefully it will be fixed in a future RR release. If you dont have this problem now then you should be ok.
    to apply the update:
    unzip the .rar file into the root of the skin and overwrite all existing files. If you are not prompted to overwrite any files you are in the wrong directory.
    Attached Files Attached Files
    beer replenishment fund
    mp3car live search
  3. #2383
    Constant Bitrate doublet's Avatar
    Aug 2005
    OKC, Oklahoma
    Thanks for the continuing update, LS.
  4. #2384
    Variable Bitrate xs10x's Avatar
    Jul 2005
    Bronx, NY
    Hey liquid any support for mappoint in the near future on this skin?
    `¨`¨`¨`¨` _____||¯.\__
    .:.:.:.:.:.:;!_(o)______(o)'i
    TruckputerX - Vortech SuperCharger Vid
    TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
  5. #2385
    Aug 2003
    Chicago
    Quote Originally Posted by xs10x View Post
    not from me, but anyone is welcome to add it and ill add it to the skin.
    Im not biased against mapppoint or anything, the only reason i say no is there is a massive number of screens for mappoint. More than i care to deal with for just gps. Id also bet any other skin that dosent support mappoint, its because of this exact reason, and also cuz it dosnt seem to be as popular as other gps apps so it kind of gets left out sometimes. I think of all the skins ive done, ive only been asked maybe 2 times about mappoint.
    So while i wont personally add it, i will support it if someone else adds it in.
    mp3car live search
  6. #2386
    Nov 2005
    Id also love to see the DSATX screen supported. And no, you dont need a net connection. You setup comfoolery to use 127.0.0.1 (which directs everything back to ur carpc ), its just that the creator wrote the app to use a TCP port instead of Serial. Perhaps thats easier to interface to. ??
  7. #2387
    Jul 2005
    Bronx, NY
    Hey liquid,
    About Notes, What do I need to modify in the code below to excluded the bold area:
    C:\My Documents\My Music\-{VOICE_RECORDINGS}-\03_MARCH\03-12-2008@07_34_AM-vNOTE.mp3
    It works perfect if I remove the bolded area for my voice recordings.
    *found in ExecTBL.ini in skin
    "vPATH","SETVAR;SLASH;\||SETVARBYCODE;myDpath;DATE ;MM||MONTH||SETVARBYCODE;myT;TIME;HH_MM_AM/PM||SETVARBYCODE;myD;DATE;MM-DD-YYYY||SETVAR;myTD;$myD$@$myT$||SETVAR;quotes;"||SE TVAR;vfolderpath;-{VOICE_RECORDINGS}-\$myDpath$_$MONTH$\||SETVAR;VOICEPATH;$quotes$$mus icpath$$vfolderpath$||SETVAR;FILE;$myTD$-vNOTE.mp3||SETVAR;vBROWSE;$musicpath$-{VOICE_RECORDINGS}-"
    "vPATH2","SETVAR;SLASH;\||SETVARBYCODE;myT;TIME;HH _MM_AM/PM||SETVARBYCODE;myD;DATE;MM-DD-YYYY||SETVAR;myTD;$myD$@$myT$||SETVAR;quotes;"||SE TVAR;vfolderpath;-{VOICE_RECORDINGS}-$SLASH$$myDpath$_$MONTH$\||SETVAR;VOICEPATH;$quote s$$musicpath$$vfolderpath$||SETVAR;FILE;$myTD$-$FILENAME$$TYPE$"
  8. #2388
    Jul 2005
    Bronx, NY
    Hey liquid,
    *Forget it, I got it working.
  9. #2389
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Smoke:
    Been looking for the movie listings in the skin, can't find it.
    No buttons for it either.
    Littel help?
    Leonardo Da Vinci
  10. #2390
    Aug 2003
    Chicago
    Quote Originally Posted by greatwhite View Post
    Smoke:
    Littel help?
    its called movietimes and its under the .net button. If you dont see it, click and hold on one of the buttons after you click the .net button and choose movietimes.
    FYI this is not the movietimes plugin just made recently, its been in the skin about a year now. I am looking into the plugin version though to see if its a better option.
    mp3car live search
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 01:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 12:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 09:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 01:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 07:00 AM
