Thread: Lsx Void 3.0
  1. #2421
    Nov 2005
    Can the Mi/h (Km/h) in the top-centre of the main screen be replaced with something else? (not for everyone - can I just mod mine?)
    The value reported by my GPS/RR is always a few seconds behind the actual value and it looks kinda silly when it says 12 and Im doing 40 .
    Maybe I could just hide it, but its a good space for another infotag, so I would prefer to display something - even the compass there instead.
    ta
  2. #2422
    Maximum Bitrate Kimota's Avatar
    Nov 2006
    Fort Lauderdale ,Florida
    Hello,
    I'm having an issue with the camera, when I click the button I only see the screen below.
    Note I have tried the camera in DigitalFX and it works with no issue. Is there some configuration in Lsx Void void I'm missing?
    Jan 2004
    Hello,
    The DSATX interface mentioned earlier needs comfoolery because flash can t connect directly to the serial port but it can connect to a tcpip port. I know there are some wrappers around flash that give it the ability to connect directly to a serial port but i oculd not get my hands on any. You will not need comfoolery to test it if you don t have a brainstem/dsatx.
    I have a small problem with this otherwise perfect skin, when i set rr to connect directly to the gps port(using xport 3 to split gps signal) it starts locking up and slowing down to a crawl, so slow i can t even exit it. I did remove the ziplocator.dll from rr's root folder as instructed but it still seems to behave this way no matter what i do. Any ideas what could be wrong? Thanks
    Alex
  4. #2424
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by at_b View Post
    Hello,
    Alex
    Interesting, your specs appear more than sufficent to run it the way you say it's hooked up.
    I's also using export and rr, no problems. (well, I do have the lag in speed readout as mentioned further up)
    what port do you have rr reading from for gps?
    Leonardo Da Vinci
  5. #2425
    Jan 2004
    actual gps is on port 3 and is split by xport 3 on ports 8 and 9. rr connects on 8. everything is speedy and working perfectly if i don t setup a gps port in rrconfig so specs should not be a problem at all. one thing i have not tried is to connect rr straight to the gps and not to xport, although that s not an option for me as i need igo readinig from the gps too
  6. #2426
    May 2007
    Sounds more like a RR problem and not so much a skin problem. Try posting on the RR sub forum.......
    Leonardo Da Vinci
  7. #2427
    Variable Bitrate warnockm's Avatar
    Jun 2004
    Virginia
    Quote Originally Posted by Enforcer View Post
    And it probably won't change till the 1st April, so live with it guys (well, live without it till then.)
    I can try to mirror it for you.
    Progress - VIA EPIA SP8000 | 120 Opus Power Supply & Case | 1GB Ram | 120GB 2.5" Hard Drive | Bluetooth 2.0 | GPRS/3G | Wifi | Road Runner/LSX 2.0 (waiting for a day skin for 3.0) | iGuidance 4.0 | Lilliput 7"
  8. #2428
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by warnockm View Post
    Huh?
    It's not mine to need a mirror.
    LiquidSmoke has said that he won't use mirrors as he (like I do for my stuff) wants to monitor the number of downloads.
  9. #2429
    Jun 2004
    Virginia
    Huh?
    just an offer. i understand. it sucks for those of us that can't download it, though....
  10. #2430
    Jan 2004
    Quote Originally Posted by greatwhite View Post
    With the same settingss but the default bmv skin it starts without a hitch...
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 01:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 12:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 09:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 01:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 07:00 AM
