APPLICATIONS:
External applications that are presetup to work with the skin.
note: all apps should installed to there default paths, dont change anything.
SYSTEM MANAGER
IF you dont have system manager installed,
go here, install to the
default path. Load the skin, click the right big grey arrow on the main menu, click
SYSTEM button
there are multiple links to the differnt versions of system manager (copytool) in that thread, the last 2 versions
5.2 ver
5.5 ver (has some reported issues)
LSX VOID SKIN for system manager, sys man can only have ONE skin at a time, so you will have to overwrite the default skin with the lsxvoid version. BACKUP the default first if you plan to use it later.
EDIT C:\Program Files\System-Manager\settings.ini and under the [GENERAL] section make the values look like below.
[General]
ResX=800
ResY=407
Top=51
Left=0
Enable Exit-Button=1
CALENDAR
Calendar support
this is a
rainlendar <---link) skin to match lsx void
800x600 800x480
These files go into the skin dir under rainlendar
C:\Program Files\Rainlendar\Skins
VISUALS
vis used in screenshots
PAINT
http://www.ambientdesign.com
instal to default path
C:\Program Files\Ambient Design\ArtRage 2
SENSOR
SpeedFanhttp://www.almico.com/speedfan.php
EMU
Mobile Emulator
