Thread: Lsx Void 3.0
  1. #2491
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    "Waiting for gps signal" means it doesn't see the gps mouse (yeah I know, duh).
    What MGD is getting at is rr is "stealing" the port from IG4 when both programs are running.
    Downlod the program "xport", it's a virtual port splitter.
    Tell it which port your gps is on, then slpit that into two seperate ports (it'll be obvious how once you run the program).
    Then tell RR which of the two "virtual" ports to use, and tell ig4 to use the other.
    Viola, no more conflict!
    I can't think of any other simpler way to describe the process............
    Leonardo Da Vinci
  2. #2492
    Low Bitrate pdegameplayer's Avatar
    Jul 2007
    Harrisonville, Missouri
    Quote Originally Posted by greatwhite View Post
    ok i did all that and the gps is working fine now but still having the problem of it not retaining any information that i input into the program it works fine when not embedded!
  3. #2493
    May 2007
    Quote Originally Posted by pdegameplayer View Post
    Are you using the flyout menu or the menu in IG4 when inputting data in the embedded mode?
    It may be a corrupted script if you can't use the flyout menu correctly.
    Try using the menu button (the big blue button) in the embedded IG program and see if that works.
    Also, if you have ig4 installed anywhere but the default location, this may cause problems.........
    One last point:
    Make sure you have the path set correctly to ig4 or you can have all kinds of funky problems with embedding.
    Good luck.
    Leonardo Da Vinci
  4. #2494
    May 2007
    LS:
    (hopefully) Small request;
    I use cdrskulls joypad 3.1 program for RR. Available here. Basically, it allows you to use a usb joypad to control RR. PLug and play simple, works right out of the box. This is useful in that I have hacked up a joypad and made hard buttons on my dash for RR functions (ie: gps, audio, dvd, fwd, play pause, vol+/-, etc)
    But I'm having an issue when calling up the gps screen with joypad. When joypad sends the command to RR to intiate the gps, it loads up just fine in void except there's no script running for the flyout screen. Any idea why this is so or how to fix it? Perhaps joypad 3.1 is sending the command to RR but void goes through the skin commands and brings up the script along with gps?
    I'd appreciate it if you'd have a quick look see.
    Cheers
    Leonardo Da Vinci
  5. #2495
    Newbie jacksmilzo's Avatar
    Sep 2007
    Rimini Italy
    hi, i write from italy
    i have a problem with your skin:
    i want change resolution to 800x600, i try to change the res in general.ini, but the skin don't change
    i had a mistake?
    ciao!!!
  6. #2496
    Newbie BReMFoX's Avatar
    Dec 2007
    The Netherlands
    I installed version 3.3 and 3.301
    How do i enable freefone again?
    | Suzuki Esteem 1.8 GTX | Intel Pentium 4 Carputer | Entertainment On A Higher Level |
  7. #2497
    Jul 2007
    One last point:
    Good luck.
    First off i have no idea what the flyout menu is second all the paths are set right and it is installed in the default location and the menu button works fine!
    the only problem im having is that it wont save!!! both the set home and favs reset immediately and clear out all data.
  8. #2498
    Jul 2007
    also how do make either the lsx void skin or rr its self stop messing with my dimming control?
    *FIXED* xport was messing up and sending weird speeds to rr like one time it sent 1025mph to it go figure right?
  9. #2499
    May 2007
    look in RRconfig.
    Sounds more like a ig4 issue if it's not saving your favorites.
    The flyout menu is the little arrow that pops up on the gps screen on the lh side and gives you quick access to IG4's features. But you're obviously not using it, so I doubt ls's scripts are the problem.
    Plus, you're starting to sound confrontational for someone with a "high tech understanding" and asking pretty basic questions, so I think i'm done replying to your posts.
    Good luck. (I mean that sincerly. I just don't need the drama)
    Leonardo Da Vinci
  10. #2500
    Maximum Bitrate Kimota's Avatar
    Nov 2006
    Fort Lauderdale ,Florida
    Quote Originally Posted by BReMFoX View Post
    Hello
    There should be a button on the main screen "PHONE" that will bring up freefone. If you need to assign a button for freefone, hold down the button you wish to use for a few seconds, when the "choose a command from the list" appears select "PHOCO".
    You will also need to specify the Com Port for "serial line via bluethooth /cable" in the settings.ini located in "C:\Program Files\Road Runner\skins\LSX VOID 3.0" if RR is installed in its' default location.
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
