Thread: Lsx Void 3.0
  1. #2501
    Low Bitrate pdegameplayer's Avatar
    Jul 2007
    Harrisonville, Missouri
    Quote Originally Posted by greatwhite View Post
    look in RRconfig.
    Sounds more like a ig4 issue if it's not saving your favorites.
    The flyout menu is the little arrow that pops up on the gps screen on the lh side and gives you quick access to IG4's features. But you're obviously not using it, so I doubt ls's scripts are the problem.
    Plus, you're starting to sound confrontational for someone with a "high tech understanding" and asking pretty basic questions, so I think i'm done replying to your posts.
    Good luck. (I mean that sincerly. I just don't need the drama)
    i am truly sorry if i sound confrontational i'm not meaning to its just kind of frustrating not knowing what i am doing on this program. don't get me wrong i love all the features and the awesome lsx void skin its just the money i forked out for a program that don't work is kinda upsetting.....
    ill try reinstalling and see if that will work... if not i guess i will have to dl a pirate copy of ig3 or something i mean i do own a license for a newer copy so it cant be that bad right? i mean i did buy it!
  2. #2502
    Newbie BReMFoX's Avatar
    Dec 2007
    The Netherlands
    Quote Originally Posted by Kimota View Post
    Hello
    There should be a button on the main screen "PHONE" that will bring up freefone. If you need to assign a button for freefone, hold down the button you wish to use for a few seconds, when the "choose a command from the list" appears select "PHOCO".
    You will also need to specify the Com Port for "serial line via bluethooth /cable" in the settings.ini located in "C:\Program Files\Road Runner\skins\LSX VOID 3.0" if RR is installed in its' default location.
    Well, the weird thing is, when i press PHONE, phonecontrol appears instead of the default freefone.
    Freefone is the default under the PHONE button right?
    I also can't turn ilists on.
    There is no option in "General options" to turn ilists on...
    Before i installed the 3.3 version of the skin including the update i completely uninstalled the old version.
    So that couldn't be the problem.
    What's going wrong here?
    | Suzuki Esteem 1.8 GTX | Intel Pentium 4 Carputer | Entertainment On A Higher Level |
  3. #2503
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by pdegameplayer View Post
    You've got something set wrong, somewhere.
    I'm using ig4 with rr and void with no issues (yes, I bought it).
    It can be something as simple as a mis-typed capital or character. You just have to approach it logically and triple check everything.
    I don't know why you're frustrated with IG4, it sounds as if it works just fine stand alone (which is what you paid for).
    Using a pirated previous version isn't going to help you if you don't have things set up correctly.
    You're just having some issues with embedding somewhere. RR isn't the easiest program to learn, but it's not the hardest. Just keep learning and looking................you'll find what's wrong.
    Leonardo Da Vinci
  4. #2504
    Jul 2007
    ok thanks ill recheck everything
  5. #2505
    Jul 2006
    Any chance you could do a sub thread somewhere on getting GE runnning in void?
    I think I remember you saying you cached the maps a s well. A how to would be great for that also.
    It' not like I couldn't figure it out, but I just haven't had the time to hack around with it myself. A littel how to would be great to get a head start.............
    Cheers
    i posted a pseudo guide towards the end of the GE plugin thread on how to cache maps and stuff. as far as embedding inside of void, all you have to do is hold down one of your buttons and change it to the GE button. LS has graciously set everything up to make it work perfectly from the get go, as long as you have your maps cached, port set, etc.
  6. #2506
    May 2007
    Quote Originally Posted by hari-bhari View Post
    Thanks, I'll have a look..............
    Leonardo Da Vinci
  7. #2507
    Jul 2007
    @ greatwhite i know this is a little off topic but its kinda ironic i know how to get google earth running in rr. if you need help i can provide that since you so kindly helped me!
  8. #2508
    Maximum Bitrate Kimota's Avatar
    Nov 2006
    Fort Lauderdale ,Florida
    Quote Originally Posted by BReMFoX View Post
    Make sure your using the latest version of RR, try reinstalling 3.3 then the 3.301 update, I've LSX Void installed on 3 machines and the default is freefone when "PHONE" is pressed.
    Also under general options your not seeing Ilist as seen below?
  9. #2509
    May 2007
    Thanks for the offer, but I'll figure it out.
    Just have to find the time..............
    Leonardo Da Vinci
  10. #2510
    Oct 2006
    Raleigh
    Does this skin has suppor for the Valentine One, if so does anyone know how to make it functional, thanks.
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
