LS, I just did a reinstall last week and I seem to have the same problem.
I'm pretty sure I haven't changed the ExectTBL.ini and I applied the patch.
I'm gonna try to apply the patch again tomorrow and see if it makes a difference.
Printable View
humm, which main menu layout option are you using? Didnt think of this before, but def could be the issue. Since there are so many main menu layouts, its easy for one of them to have not been updated properly.
Try switching to a different main menu layout and see if the OPT button goes to the correct screen.
so when i use SIRIUS after hibernation or exit n restart RR all my songs get deleted... and it just plays the basic FOLDER that i started with...
also resume doesnt work and a few other functions are funny
i take Sirius out... keeps songs, loads fine, resume works... sooo i dunno what or why it would cause that
I'm having a problem with the tags on my songs. I don't know if this is a issue with the skin or RR itself, can't really tell as this is the only skin I use. But when I first load a playlist all the tags are fine, after a while (I don't know the exact time or how many standby's) the tags will mess up on some songs. It will show a tag of completely different song or only part of the tag will show. There are other times when the album art will be wrong, it will be of a different album that is in the playlist. I've has this problem with previous version of this skin as well, so I can't exactly pin piont where the problems comes from.
Does anyone else have a similar issue with their tags?
I'm running the recommended version by LS. what version are u running?
