Thread: Lsx Void 3.0
  1. #2581
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Quote Originally Posted by liquid_smoke View Post
    i took a look at your debug file, and it is indeed loading the old version of the options screen.
    I also downloaded the 3.301 update and looked in the ExecTBL.ini file and its set up correctly to point to the new options screen.
    Have you applied any other updates after the first two links on the first page?
    Are you certain you have the latest version of RR. In the options screen (new or old) there is an about screen, go there and tell me the RR version date and also the skin version number you see in the top left and right corners of that screen.
    also, post your ExecTBL.ini file that is inside of the skin.
    In the mean time, try to re apply the 3.301 update
    LS, I just did a reinstall last week and I seem to have the same problem.
    I'm pretty sure I haven't changed the ExectTBL.ini and I applied the patch.
    I'm gonna try to apply the patch again tomorrow and see if it makes a difference.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  2. #2582
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    humm, which main menu layout option are you using? Didnt think of this before, but def could be the issue. Since there are so many main menu layouts, its easy for one of them to have not been updated properly.
    Try switching to a different main menu layout and see if the OPT button goes to the correct screen.
    beer replenishment fund
    mp3car live search
  3. #2583
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by wywywywy View Post
    Hi,
    I use Sygic within LSX without any problems.
    First of all you NEED to specify the width and height.
    But try to do it in an AutoIt script and compile it all as exe file, and launch the new exe file with RR.
    Secondly, I would recommend using one the of "empty" buttons instead of the GPS button in LSX.
    HTHs.
    Oh... I think I'm one of the last CarPc builders out here that hasn't done anything in AutoIT yet... you don't happed to have a pre-built one that I could use... otherwise I guess I'll just finally have to try it out myself!
    Swedish site for CarPC's
    http://www.bilpc.info
  4. #2584
    Newbie BReMFoX's Avatar
    Dec 2007
    The Netherlands
    Menu lay-out?
    I tried changing the visuals if that is what you mean, but that had no succes.
    | Suzuki Esteem 1.8 GTX | Intel Pentium 4 Carputer | Entertainment On A Higher Level |
  5. #2585
    Dec 2003
    New York
    I didn't change the menu layout, its the stock one that comes up by default when u install the skin. Its the one without the iList playlists.
    Installed
  6. #2586
    Feb 2006
    Quote Originally Posted by Naesstrom View Post
    Not with me at the moment, but will get it in the next few days.
    (If I don't, please PM to remind me.)
  7. #2587
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    so when i use SIRIUS after hibernation or exit n restart RR all my songs get deleted... and it just plays the basic FOLDER that i started with...
    also resume doesnt work and a few other functions are funny
    i take Sirius out... keeps songs, loads fine, resume works... sooo i dunno what or why it would cause that
  8. #2588
    Dec 2003
    New York
    I'm having a problem with the tags on my songs. I don't know if this is a issue with the skin or RR itself, can't really tell as this is the only skin I use. But when I first load a playlist all the tags are fine, after a while (I don't know the exact time or how many standby's) the tags will mess up on some songs. It will show a tag of completely different song or only part of the tag will show. There are other times when the album art will be wrong, it will be of a different album that is in the playlist. I've has this problem with previous version of this skin as well, so I can't exactly pin piont where the problems comes from.
    Does anyone else have a similar issue with their tags?
    Installed
  9. #2589
    Low Bitrate pdegameplayer's Avatar
    Jul 2007
    Harrisonville, Missouri
    Quote Originally Posted by Quattro View Post
    i had a very similar problem and i updated winamp and it went away.. but your problem may be different just a suggestion......
  10. #2590
    Dec 2003
    New York
    I'm running the recommended version by LS. what version are u running?
    Installed
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
