Thread: Lsx Void 3.0
  1. #2621
    Jul 2005
    You'll have to excuse me, I searched as best I could but couldn't find any details on estimated system requirements. From your experience, what can you tell me about how this skin performs on various systems? I'm thinking of building a new computer just so I can run this skin, the video looks incredible.
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    The Dll is named ZipLocater.dll which is included in the 12/06 beta that is out and about. Once i removed that dll everything started working including the heading indicator that never worked for me before.
    I do have another question that hopefully someone may be able to answer. How do i change the video in the weather section Weather--> Radar--> Forcast?
    It loads some video from chicago. Is there some place i change that to point to a local source. I looked all around but couldn't find that particular skin file.
    Any help would be greatly appriciated.
  3. #2623
    Variable Bitrate kelmk's Avatar
    Aug 2007
    SF
    Quote Originally Posted by MunkyWrench View Post
    for anyone whos wondering about this,
    heres how i have gotten around the problem of ilists resuming blank.
    in exectbl.ini
    "ONSUSPEND","LOAD; black.skin"
    "ONRESUME","ESC"
    its not a new idea that going to a skin without an ilist avoids the ilist problem,
    but lsx has the blackout skin (very simple skin) just sitting there so its a nice work around.
    on my system it appears to 'just work' with no short glimpse of some random screen at resume.
    I tried this but it doesn't work for me. The only thing I can do is either reload the whole skin or switch to a non ilist screen before shutting down. I have no idea why the above code wouldn't work though.
  4. #2624
    Jul 2005
    Well, I decided that whatever system I put in now is just going to be overkill for running roadrunner or even streetdeck for that matter, so I won't worry about the system requirements.
    I feel ashamed that my car PC will be faster than the old 1.7 Ghz Desktop I check my email and do schoolwork on. I can't even get itunes visualizers to run on that thing without slowing it down, ha!
  5. #2625
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    Quote Originally Posted by antimatter View Post
    Is This what your looking for antimatter?>> http://www.mp3car.com/vbulletin/rr-s...her#post985857
    If you cant DODGE em, RAM em.
  6. #2626
    Low Bitrate pdegameplayer's Avatar
    Jul 2007
    Harrisonville, Missouri
    Quote Originally Posted by Thrasher865 View Post
    it runs hella fast on a core 2 duo extreme!!
    and runs very well on a 2.6 ghz celaron also those are the only ones ive tryed it on!
  7. #2627
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    i just (finally) got a new carpc and the cpu is 900MHz Celleron M with 512Ram and the skin runs perfectly on it, with ilist enabled and screen transitions turned on. So i would have to say that anything that is above this should be more than enough.
    The skin is developed on a 2GHz Pentium M with 2GBram and nvidia gfx card.
    Tested on a 2.6GHz celleron and an old P4 laptop. I have yet to find a box that it runs slow on.
    Quote Originally Posted by greatwhite View Post
    Deos anyone now if the current 3.3 download has the 3.301 update incorporated already?
    NO
    3.301 was released after 3.3
    I found an/some issue/s with the playlist browser. (AUDIO -> LIBRARY -> PLAYLIST)
    I am using iLists.
    My playlist directory is set correctly.
    when looking at my playlist directory it functions normally, load/save/rename playlists.
    but when i assemble a new on the fly playlist and then hit save, and type in a name, and press enter, the iList does not update itself to display the additional playlist that has been saved to my playlist directory.
    the playlist IS created/present in my playlist directory.
    if you rename a playlist even renaming it to the exact name it had before, then the iList DOES update.
    by double clicking on a playlist in the iList, I can browse into the playlist and see the individual songs
    but I can't back out of the playlist at all. theres no button for it.
    so my playlist editor is stuck inside ironmaidenplaylist.m4a until i restart RR.
    and hitting rename renames my music files! DANGER
    so in summary:
    -ilist doesnt update when a new playlist is saved to the playlist directory.
    -can browse right into a playlist and cant back out.
    -can rename my mp3s - surely not intended??
    i take it that playlist menu is not supposed to browse into the playlist files?
    if i'm missing the point i apologise.
    hope ive given enough detail
    thanks heaps for your work, smoke.
    will take a look into these issues.
    From top of the head though, you should not be able to browse into the playlist, it should play the playlist instead of showing its contents.
    How are you able to rename your mp3 files?
    Quote Originally Posted by kelmk View Post
    Is it possible to add a button to load a website? I like the way the .net menu does it with no menus or borders on the browser but I can't figure out how to add a custom url. I just want a page to load up pandora.com
    there isnt an easy way to add a custom url to those .net buttons. What i will do in the future though, is rebuild the system so each url is custom.
    the code he pasted would only work if your sytem is set to standby when u shutdown instead of powering off. What ill do though since this is an easy workaround is build that blank.skin into the shutdown commands, so no matter how you exit, it will always go to the blank.skin screen first then exit.
    beer replenishment fund
    mp3car live search
  8. #2628
    Nov 2006
    i am able to rename songs by browsing into the playlist by double clicking on it in the ilist, and then hitting rename. the OSK comes up with the path to the song in it.
    It didnt rename it right away, so I thought it was messing with the playlist entries, but after fiddling with RR and restarting a couple times I noticed the changes I made had in fact been applied to the mp3 filenames.
    If it doesnt appear to rename them, give a RR a few restarts/ a break or whatver, mayb change to another playlist. im not sure exactly how to reproduce, but it DOES rename them.
  9. #2629
    Aug 2003
    Chicago
    well thats definitely not the intended functionality. The rename button is actually to rename the playlist file. But its arguable of which way should be the correct way, i can see some people wanting it this way, others the other way. Ill take a look and see if this has changed in RR and if not then look into why its doing it with the skin. Or see if there is some option to check to toggle the different methods.
    mp3car live search
  10. #2630
    Jan 2004
    California
    Quote Originally Posted by Ramanator View Post
    That is what i am looking for but how do i find a link for my home area i.e the california san francisco bay area
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
