Thread: Lsx Void 3.0
  1. #2651
    Variable Bitrate eric_barcus's Avatar
    Mar 2007
    for the finger scrolling it is the ilist feature in the menu go to
    -opt
    --general options
    ---then almost ll the way down to turn ilist on
    enjoy!
  2. #2652
    Low Bitrate Ali_2k's Avatar
    Oct 2005
    Quote Originally Posted by eric_barcus View Post
    -opt
    --general options
    enjoy!
    hah.. yeh, just worked that one out... its been a long day :P
    cheers tho
    on the topic of ilists, can i remove the "static" buttons that are used when ilists are disabled seeing as i wouldn't use em now?
    2k
  3. #2653
    Jul 2006
    is anyone having problems with the new installer? everytime i try to unpack it on my carpc, it stops at one of several files. usually its vista.pdd but sometimes its one of the background.jpgs or the diskcheck.exe (or is it harddisk.exe) file. i have tried redownloading several times, but with the same results. i tried unpacking the same file on my other pc and it works fine. so i reinstalled xp pro from scratch, ran a chkdisk and tried again with the same result. weird thing is that if i unpack the older void 3.0 it works with no problems. what could be going on, any ideas??
  4. #2654
    Newbie Nickman's Avatar
    Dec 2007
    Atlanta
    LS -
    I don't know if you have seen this, MeHere, program. http://mehere.glenmurphy.com/ . This adds moving GPS traking to GoogleMaps. Its free. I think the ability to track movment on a searchable map is paramount. Since googleearth has given many much grief, I thought this may be a useful addition.
    nm
    Planning (0000000000) 100%
    Purchase (0000000000) 100%
    Fab/Install (000000000-) 95%
  5. #2655
    Dec 2007
    Iowa
    Quick question has anyone got avs to continue running in the background when you switch screens?
  6. #2656
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by greatwhite View Post
    Hold on.................
    The drop down menu is no longer there. I get "notes" when i click on the upper LH corner...........
    Problem solved I guess. The menu must be removed in the latest 3.3? I just Dl'd a fresh copy of void the other day, I was running the "old" 3.2 in the car up to today.........
    the menu was not removed or changed in any of the versions. Sounds like you may have assigned the command for that button by mistake. If you click and hold on the button, a new screen with a bunch of buttons should show up, choose "MENU" from the available options. Other buttons on this screen also behave the same way.
    Quote Originally Posted by hari-bhari View Post
    kind of sounds like something odd with that specific pc, esp if you are able to install the same file on another pc. If you already have had 3.0 installed on the troubled machine, i would just copy the 3.2 install from a good machine over to the problem one.
    Quote Originally Posted by Quattro View Post
    After some testing, I believe the problem I'm having is skin related. I've been using the Shock skin for a couple of days and did not see anything similar to what I described above. then toaday I used void and I had a song by mario where the tile was correct but the artist and album art was of alica keys. I switched to shock and everything was correct and then I switched back to void and everything was correct then.
    LS, any ideas of what might be happening?
    cant say ive seen this before. What version (version date) of RR are you running?
    Quote Originally Posted by Bxsteez View Post
    After trying for hours to get freefone to work i gave up and am trying RRMobile but the problem i run into is that the software starts up once RRMobile starts up. Can someone point me in the direction of the area with the start up procedures? Or give me some sort of advice on getting phone control through either one of these phone control programs
    i believe freefone may have been based on RRMobile, not 100% sure though. RRMobile will load RR when it starts also. If you click OPT>Phone Settings you can change which phone app loads. RRMobile is not supported by default though, so you would have to do some mods to get it to work. The reason RRMobile is not supported is because the author of the app has abandoned future development.
    Quote Originally Posted by Nickman View Post
    LS -
    nm
    ive played with it a few times in the past, but its not really suitable for incar use. Reatime gps tracking on a google map is top priority though.
    beer replenishment fund
    mp3car live search
  7. #2657
    Constant Bitrate b3tts32's Avatar
    May 2006
    Arlington, Tx
    Smoke
    I have 2 requests.. I'm not sure if they're feasible or not but I thought I would at least ask.
    1. Is there any way from the xplorer window to transfer from another drive besides the c drive? I have no optical drive so I usually just plug my jump drive in and transfer my new music. I would like to do this from the skin but I only have the option to transfer anything from the c drive.
    2. This is probably a stretch.. but I use the color picker to use a color for my day skin and a theme for my night skin. I usually have to go through about 5 or 6 buttons to do this. Is there any way I could do a macro or something to simulate going through all of this with one button? It's not a big deal but I figured I would at least ask.
    Thanks in advance
  8. #2658
    Jul 2006
    turns out i couldnt install ANY program. did a hard disk check, came out fine. turned out it was bad ram. go figure!
  9. #2659
    Jul 2006
    Quote Originally Posted by MunkyWrench View Post
    for anyone whos wondering about this,
    heres how i have gotten around the problem of ilists resuming blank.
    in exectbl.ini
    "ONSUSPEND","LOAD; black.skin"
    "ONRESUME","ESC"
    its not a new idea that going to a skin without an ilist avoids the ilist problem,
    but lsx has the blackout skin (very simple skin) just sitting there so its a nice work around.
    on my system it appears to 'just work' with no short glimpse of some random screen at resume.
    i tried it out and it didnt work for me, then i realized there is a space between the load command and the skin name. it should read:
    "ONSUSPEND","LOAD;blank.skin"
    "ONRESUME","ESC"
    that code should work for everyone now. by the way, im using blank.skin, not black.skin. i think blank is the one for blackout, whereas black just makes RR disappear or become transparent or something. anyhow, this patch works and now i can go into standby on any screen without worrying about my ilists messing up. woohhoo!
  10. #2660
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by b3tts32 View Post
    Upd8 can do this automatically
    [/shameless plug]
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 01:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 12:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 09:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 01:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 07:00 AM
