inside rrconfig disable "no internazional..."
I have ploblem. What about number 7 8 in button.. please help me.
Smoke:
You were right about the drop down quick menu. I either changed it by accident, or something happened, dunno. Fixed.
I also checked for the clipping setting, but it was already enabled. Cycled it off, no difference. Turned it back on, and it worked. Must have not been written to the ini the first time for some reason. Meh, dunno.
But, new question:
When I embed my OBDII program (dashcommand), everything works fine until I try to navigate music or volume.What will happen is the embedded rogram will flash in and out during selections. IE: press FF and the embedded program disappears and reappears lng enough to see the underlying black screen where it would be embedded.
Is this a normal action or is something not set correctly in my config?
Native support for this program would be great, and at 20 bucks for a touch screen freindly OBDII program, you can't go very much wrong...........
Cheers
Leonardo Da Vinci
Thanks jacksmilzo...
ok i went into the gps and the compass was disabled. I enabled it and now there is a compass bar where the white spot use to be. I would just like to hav it with no compass and no white spot...like the screen shot on the first page. I updated flash player however I dont have Internet exporler installed, is that a problem?
superfly i did the same thing, installed hte flash update and same white bar issue
ALSO ive seen people with differnt color compass' how do we change it from the blue to something else or see thru like ive seen aswell
two lsx void noobs looking for answers now AFTER following the recommended update without seeing change
I've converted my itunes library album art to jpg and am able to see the album art in the library now. However, the album art will not show up on the main screen when the song is playing, it just says no album artist, like the picture a few post up. I am also trying to get rid of this white bar still and have had no luck.
Leonardo Da Vinci
Leonardo Da Vinci
hey guys im curious
ive noticed that if i have a vidual on and switch to iguidance then close it and return to the music its super slow and rr reacts ALOT slower too, but if i stop the plugin then restart it everything is fine, ive made the visu process less info and everything cant seem to fix that, maybe the iguidance map is takeing alot of ram?
