Thread: Lsx Void 3.0
  1. #2671
    Variable Bitrate super-fly's Avatar
    Feb 2006
    NJ
    my library is: main music folder>artist folder>album folder. The album folder then contains the songs as well as the album .jpg. I believe this is correct no?
  2. #2672
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Quote Originally Posted by Quattro View Post
    After some testing, I believe the problem I'm having is skin related. I've been using the Shock skin for a couple of days and did not see anything similar to what I described above. then toaday I used void and I had a song by mario where the tile was correct but the artist and album art was of alica keys. I switched to shock and everything was correct and then I switched back to void and everything was correct then.
    LS, any ideas of what might be happening?
    Quote Originally Posted by liquid_smoke View Post
    cant say ive seen this before. What version (version date) of RR are you running?
    Nevermind, my problem is not related to just your skin. I happened with the shock skin today as well, a few times actually. So, this problem starts to happen after a few days use of the same skin and it fixes if I change the skin to a different one. Maybe RR related, idk.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  3. #2673
    Jun 2007
    Audio Controls in GPS Screen
    I've read over the thread in the last few days so please bear with me if I've missed it as I've tried using search.
    I have my screen set to 800x600 (Monitor won't do 800x480 correctly) and when I enter into iGuidance through RR the audio controls that load are right ontop of my 'Zoom In' button. How can I change the position of the 'AUDIO_CTRL' script to move it down so it is not in the way? I remember it possibly being embedded into the skin but I'm not entirely sure. Any help would be greatly appreciated and as always, amazing skin!
    I checked in RRSkinEditor to see if it was in the External_GPS_FS skin but I don't seem to see it there, possibly in some .ini file? Thanks again.
    -Server
  4. #2674
    Dec 2007
    Iowa
    This might be something obvious but did you check if you change the external gps skin layout and see if the problem is still there?
    Go into options and then gps i believe and u can change the layout of the gps screen.
  5. #2675
    Jun 2007
    Quote Originally Posted by Bxsteez View Post
    Thanks for the reply but it had to do with where the Audio_ctrl script loaded as in x,y coordinate in the FS layout. I managed to track it down in the ExecTBL.ini file and saw that it read '500 280' so I changed it to '500 400' and it was perfect. Next time I'll try digging around some more before I post. Thanks anyway.
    -Server
  6. #2676
    Variable Bitrate eric_barcus's Avatar
    Mar 2007
    quick one guys, when on the mixer screen should the EQ presets be saving volume too cause it is on mine is there a way to disable this? where does the eq setting saved?
  7. #2677
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    When you click and hold the buttons for presets, it will save all sliders like winamp volume, preamp, wave, aux and all others. You can not disable any of those. When saved, RR creats a file with the name of the presets like BASS.pst and so on.
  8. #2678
    Feb 2007
    Iguidance Onscreen keys
    Hi I have searched and struggled and can't seem to find out how to turn off the native iGuidance buttons.
    I have both the LSX menu buttons and the iGuidance buttons on screen at the same time
    Can anyone point me in the right direction. In the meantime I'll continue to search
    Cheers
  9. #2679
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Do you mena the iguidance buttons or the void IG buttons?
    I don'think you can turn off the IG buttons from within IG.
    I got rid of mine when I used IG3 by using reshacker to relace teh image with a 1x1 pixel image. If you just remove it, IG will crash.
    I haven't treid it in IG4 yet.
    As for the Void buttons, it's run from a script if i recall. If you kill that, you might get rid of the buttons. Not sure though, and make sure you copy any files before you delete or change them.
    Good luck.
    Leonardo Da Vinci
  10. #2680
    May 2007
    Hi LS,
    HAs there been any developement on the day screen option?
    I gave up on modifying void a while ago, but am taking another stab at it:
    That's about a half hours worth of work. Mostly using "ctr-I" and adjusting the lsxcolors file.........
    I have to work on bringing back some orf the contrast and testures of the "dark" void though. Shouldn't be too hard with the original as a template..................
    Leonardo Da Vinci
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
