Thread: Lsx Void 3.0
  1. #2681
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Video Browser Cover Art not showing
    Found a few references to this problem but no definite answer. When i first go into the video browser, one of the cover arts within the highlighted folder shows up but when i browse inside that folder, the art don't show; all that shows is those arrows.
    The jpgs are named like this:
    Artist - Song.avi
    I tested changing the name to Artist - Song.jpg (without the .avi) but nothing.
    I have icons turned-on and running the latest rr. The art shows fine in other skins.
    I wander what it is?
  2. #2682
    Feb 2007
    Yes i meant the ig buttons, time to investigate reshack
    Thanks for the tip!
    Cheers
  3. #2683
    Jul 2006
    http://www.mp3car.com/vbulletin/soft...reshacker.html
    Quote Originally Posted by Twisty View Post
    Thanks for the tip!
    Cheers
  4. #2684
    Variable Bitrate eric_barcus's Avatar
    Mar 2007
    Quote Originally Posted by MGD View Post
    When you click and hold the buttons for presets, it will save all sliders like winamp volume, preamp, wave, aux and all others. You can not disable any of those. When saved, RR creats a file with the name of the presets like BASS.pst and so on.
    then were can we find these .pst files? i mean ill do a search on my computer but i figure they have to be editable somehow, we can just leave winamp vol alone, i mean in the winamp application its self the presets are not saving the winamp vol and i think its silly the skin saves them when all your trying to do with eq is change the individual bands not the volume its self
  5. #2685
    Mar 2007
    GREAT JOB GREAT WHITE! id like to see the day skin come to life! id use it! 5*
    Quote Originally Posted by greatwhite View Post
    Hi LS,
    HAs there been any developement on the day screen option?
    I gave up on modifying void a while ago, but am taking another stab at it:
    That's about a half hours worth of work. Mostly using "ctr-I" and adjusting the lsxcolors file.........
    I have to work on bringing back some orf the contrast and testures of the "dark" void though. Shouldn't be too hard with the original as a template..................
  6. #2686
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by eric_barcus View Post
    Thanks.
    But the real credit goes to LS for making the skin in the first place.
    It's not very easy working from the PNG files, it sure would be alot easier if I had the "unflattened" .psd files.
    Then I could just adjust the layers instead of the entire image and the resulting "little problems" with that procedure.
    I don't think LS will release those though, I've asked before. Understandable, he's got alot of work into it. I wouldn't want to either............"intellectual property" and whatnot.
    Cheers
    Leonardo Da Vinci
  7. #2687
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    The *.pst files are created and stored in the RR directory. Here is the content of one file.
    0
    36
    15
    20
    27
    31
    34
    25
    19
    16
    13
    10
    50
    0
    655
    655
    0
    0
    You're right, the volume should not be saved when trying to set EQ presets. This function is hard coded in RR.
    REQUEST:"GUINO, please make it not save the volume sliders"
    Thank you.
  8. #2688
    Mar 2007
    0
    36
    15
    20
    27
    31
    34
    25
    19
    16
    13
    10
    50
    0
    655
    655
    0
    0
    Thank you.
    AWESOME i wrote that reply LATE last night so i havent had time to work on it yet (Straight to work this morning) but lunch will almost def be in the car editing the file...
    (hr later)
    this is what ive learned from playing with the file (couldnt find the bass and treb control)
    Code:
     130 - winamp VOL 255max
     31  - preamp 0 max 31 middle 63 off
     31 60 hz
     31 170 hz
     31 310 hz
     31 600 hz
     31 1k
     31 3k
     31 6k
     31 12k
     31 14k
     31 16k
     50 MASTER BAL 50 is LEVEL 100 is full RIGH
     16461 Master VOL 25%
     32846 Wave VOL
     0 SW Synth VOL
     0 Phone vOL
     32846 AUX VOL
     0 VIDEO VOL
     0 Mic VOL
     65692 LINE VOL MAX
     32846 CD VOL MID
     0 Nothing on mine
     0 ditto
    Mine is mapped to master
    AND when i go into the Volume Contol on my computer and then go into the properties and put a check mark next to EVERY input the inputs on the VOL CTRL corrispond IN ORDER to the numbers above starting with the Master VOL
  9. #2689
    Mar 2007
    BTW i did some testing in the car last night and i removed the number below the 50 that stands for "MASTER BAL 50 is LEVEL 100 is full RIGH" and it makes it so that the EQ changes and the VOL stays the same hope this helps you guys, i removed it from all my eq presets and now i have a true eq
  10. #2690
    Mar 2007
    QUESTION: If I am using the GPS OPT for layout number 3 with iguidance WHICH .skin file do i add the NO GUESTURE information to i was looking for gps3.skin but i only see a gps2 and a gps1 skin file
    also if anyone has already got the No guesture information for size and location exmple
    Code:
    NG,0,0,800,550
    let me know
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 01:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 12:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 09:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 01:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 07:00 AM
