Did all this along time ago, if you hit the button to store the same info, it will save the old settings again.
Printable View
can you clear up your response i mean i know that if you edit the .pst file and take out the vol line like i say, then you go back to save the preset it will over write the file that the way the EQ is set up right now in the RR programming
hey guys just wanted to clarify that BLUE ZX3 says our EQ issue is not a bug with RR but simply a setting in skin itself look here
EQ ISSUE AND FIX
FOUND A FIX FOR THIS CAUSE IT WAS BOTHERING ME TOO
open up the Radio_Player.skin
look for this code
Change the 24 to a 22 and the 40 to a 38 no more choppy choppy graphic,Code:L01,191,154,70,43,#COL1WR#,#COL1WG#,#COL1WB#,24,#FONT1#,"FMAM","CENTER"
L01,470,167,40,27,#COL1WR#,#COL1WG#,#COL1WB#,14,#FONT1#,"BYIND;HDACTIVE;=<<=HD||HDSUB","RIGHT"
L01,280,154,170,43,#COL1WR#,#COL1WG#,#COL1WB#,40,#FONT1#,"FREQUENCE","CENTER"
BUT got a question for LS where is the height of this area defined? the font size is easy one, but is the X,Y,W,H the size of the box that holds the information?
going to play with that now :D
:hippie:
would anyone happen to have one of the earlyer versions of this skins graphics? like the one in the "preview" images included in newer versions, theres some menues i think looked better in older versions and would like to replace them.
this is one of the preview images, note how its not so "button" heavy, looks a bit smoother imo:
http://i17.photobucket.com/albums/b8...review_1-1.jpg
so yeh if anyone has an older version, or the psd's/images whatever, lemme know
Anyone figure out how to disable the screen saver?
