yay no prob's but you'll have to wait till tomorrow because its on my laptop at my house and im not at home.
lmao i guess i can rar up the images and mediafire them!
ive got the radio skin working for HD3 radio channels thanks to mitch if there is a want for it ill post it FYI
OHH and quick question
i think its a little bug, im sure its a quick fix not sure thou
When in the Radio player if you change some of these buttons (with the hold down presedure) they change elsewhere in the skin
example one
change the top left button to what ever you want then
when going in the audio player (after pressing "audio" on main.skin) you get the songs in the middle and buttons around the list the top left button default is suppose to be NAVI i do belive, but it is now the same as the button you selected on the RADIO skin
ALSO cahnge the forth button to something (default is audio)
now on the main screen your audio button is replaced by the choice on teh prev screen,
dont think this happens else where in the skin, not that ive found at least
help?
unfortunately, the only way to use the older images is to use the older skin. Just copying and pasting the old images into the new skin folder wont do anything and the skin will still look exactly the same. The old file names arent referenced anymore, the image file types arent even the same. The old skin used .jpg's and the new version uses .png files. There are also a significant amount of changes to the code under the skin, so unless you like to punish yourself i wouldnt even try to do it.
beer replenishment fund
mp3car live search
Hello,
I've been trying for some time now to integrate EL CAMINO Wifi Manager into LSXVOID skin, but no luck after various tries.
- put the wifi_man.exe into rr folder, created a wifi_man.ini file in the rr folder with adapter name, pause, no devcon number since my device don t have one.
- added the following line to rr.ini startcommand=RUN;$rrpath$wifi_man.exe
- copied wireless.skin and wireless.exe in LSXVOID folder
- added the following line to execTBL in LSXVOID skin folder
"WIRELESS","LOAD;wireless.skin||SETTOPMOST;RR; TRUE ||RUNQW;$SKINPATH$\wireless.exe;Wireless Network Connection||GETFOCUS"
here I am not sure where in the ExecTBL to put it.
and put the skin file in the road runner skin file
Once I RR, when I setup the new button, I input:
APP Name: WIFI
PATH TO APPLICATION: here I can t browse into LSXVOID folder to point wireless.exe which is inside !? When double click on LSXVOID folder instead of going into that folder, he is gonna take c:\RR\SKINS\LSXVOID as path to appli
WINDO NAME: WIRELESS
Once done if I click the wreated WIFI buton, he s going back to the embed screen.
Thank you for your help.
BeuZ
