Thread: Lsx Void 3.0
  1. #2761
    Mar 2007
    I'm in love
    I'm totally in love with this skin! But it makes RR bite the dirt for me ... I can't figure out what's going on. It all works until I click on Audio... then RR freezes. Are there any special settings that I need to set, programs I need to install?
    I'm running xp in a vm on a macbook pro, I have DriectX 9c installed, mplayer classic, VisualBasic 6.0 runtime redist, and winamp 5.5ish. This is just my test setup so that I don't have to do any mass installing on a 7" monitor, lol. Sorry if this is noobish...
  2. #2762
    Constant Bitrate slvrsol's Avatar
    Mar 2007
    try registering directx 7.. probably a iList problem.
  3. #2763
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    Sounds like an ilist problem. Try disabling it.
    If you cant DODGE em, RAM em.
  4. #2764
    Mar 2007
    Quote Originally Posted by slvrsol View Post
    I have directX 9... How do I register 7? It is an I list problem, I can comment it out and it works just fine. Thanks!
  5. #2765
    mezz64's Avatar
    Nov 2004
    PA
    Blog Entries
    1
    Quote Originally Posted by liquid_smoke View Post
    garmin mobile support will be included very shortly.
    Currently testing the next update.
    Any more updates on this? Will we see the update before the end of July? I've got a few trips coming up in August and integrated garmin mobile would be awesome. I can lend you a hand with the testing as well if you'd like.
  6. #2766
    Jul 2006
    Quote Originally Posted by greatwhite View Post
    Seems to do everything my visteon offers. Analog, HD, subchannels, rds, etc................
    More than mitchjs's pcr software actually, as the skin file allows direct tuning.
    Not sure if there's anything else that hd offers that's not there already.........
    i wanted to get hd radio working on this skin and i was hoping someone could give me a quick overview of what needs to be done. as far as i know, the visteon hdz300 is the tuner we need to buy, connect the audio to the line in, usb via mitch's cable, download the dll, download the skin posted in this thread, and we're good to go? is it working pretty well for you or is it buggy? also, something that is very important for me is when you switch away from the skin, does it turn OFF the unit, or does it just mute the input on the sound card? this is very important for me because since i use kxproject drivers for my audigy card, rr cant control any of the windows mixer components aside from master and wave. any help would be appreciated. thanks.
  7. #2767
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by hari-bhari View Post
    Pretty much. I'm using the visteon also. Select HDradio in config as well. I had to downlaod hugenious's file (search should find it) for HD to work in void, although void supposedly has it already incorporated. Your results may vary..
    Works fine for me, no problems. Well, reception is poor but that's because my car has an in-glass antenna as opposed to a mast style. Those with the regular antenna get great reception apparently.......
    Neither, keeps playing just like the "audio" screen does. You have to go to the audio screen (or video) for it to change/stop.
    I'm using an audigy 4 and the kx project too. No issues. Just make sure you use "line in" and not "mic". I did at first and there was horrible background noise. Line in is stone dead quiet............
    Good luck
    Leonardo Da Vinci
  8. #2768
    I noticed the heading arrow is 180* off...instead of pointing north, it points south for example...
    Also have the empty menus when selecting options, but I dug up some stuff about a fresh reinstall of RR and the skins fixed it so I'll give that a shot
  9. #2769
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by aznblueeboi View Post
    I've only noticed that if I've loaded the program but haven't moved the vehicle yet. It corrects it self as soon as you start driving.
  10. #2770
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    I'd love to see a day skin for the LSXVOID...it is the one who works best for me - everything works but, unfortunately, it looks bland during day time. It looks GREAt at NIGHT. But on day light, I can only see the letters. The background looks the same, no matter what I chose. I even pick a white background with the colorpicker, but what looks white there, turns it self into grey when saved as background...
    Black = mirror...
    We need more white on this skin...please!
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
