Thread: Lsx Void 3.0
  1. #2791
    Low Bitrate Twinsen's Avatar
    Apr 2006
    Memphis, TN
    Awesome, exactly what I needed. Why is the default set to 0? Doesn't matter now I guess.
    Another easy question, how do I get the Calender (Rainlender) to work?
    Also, any suggestions on a Calulator app that embeds well to use as a calc?
    AAAAAAAND, has anyone tried to add the MovieTimes application found here? If so, how do you add/Embed it to RR? Found here...
    http://www.mp3car.com/vbulletin/rr-p...-near-you.html
  2. #2792
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    Quote Originally Posted by Twinsen View Post
    the default is set to 0 because not everyone wants to use GPS based weather/location labels. In fact, anyone outside of the US cant use the labels. Thats why i made the default 0. Technically you can still use GPS based weather without localdatacaptureinterval. You would just run LOCATE prior to running WEATHER.
    Live mp3Car Facebook Chat
  3. #2793
    Apr 2007
    Quote Originally Posted by mshale View Post
    I can't answer #1, but #2 you can "fix" by turning the auto album art option off. You can' find it in the OPT section of the skin in 3.3.
    I checked under options. Go to the album art option and I didnt see a way to turn it off. I only saw an option for big or small.
    I saw that the 3.301 update added the "Idle Screen" this is what Im trying to disable.
  4. #2794
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Anyone else having troubles with "theme's"?
    I downloaded a fresh copy of 3.3 and now when I select a theme (ie: envy, etc) the main menu changes to the selected highlight color, but screens like "options" don't change and still show red highlights..........
    Bug?
    Leonardo Da Vinci
  5. #2795
    Mar 2007
    Quote Originally Posted by BobbyCreekwater View Post
    oddly enough it isn't in the album art section... I'm not in my car right now, so I can't really give you a step-by-step, but I'm sure its in there because I changed it. Keep looking try the personalize section. That rings a pretty bell LOL. Good luck!
  6. #2796
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    You can also do it manually by uncommenting (/, in front of it) this line in audio_player.skin or delete it all together.
    I prefere the motion (when tracks change) of the album art changing to playlist; seing the playlist (ilist) scroll for a song; then change back to album art. My passenger's jaws always drop!
  7. #2797
    Apr 2007
    Quote Originally Posted by treetop777 View Post
    Big Thanks!
  8. #2798
    Jun 2007
    Hi guy...How I can play audio cd and media in my flash drive when I insert. LSX can't play autorun??
  9. #2799
    Apr 2006
    Memphis, TN
    Can anyone answer these questions?
  10. #2800
    Constant Bitrate b3tts32's Avatar
    May 2006
    Arlington, Tx
    Quote Originally Posted by greatwhite View Post
    Bug?
    I hadn't had any issues with themes after newly installing my system a few times (had to switch hard drives). I'm sure you've uninstalled lsx completely then deleted the folder in the skins folder?
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 01:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 12:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 09:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 01:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 07:00 AM
