Thread: Lsx Void 3.0
  1. #2801
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by b3tts32 View Post
    I hadn't had any issues with themes after newly installing my system a few times (had to switch hard drives). I'm sure you've uninstalled lsx completely then deleted the folder in the skins folder?
    Sorry, should have updated. Found my issue, I had mistakenly put the skin files in the wrong folder.
    Fixed.
    Leonardo Da Vinci
  2. #2802
    May 2007
    So here's my little contribution to the LSX thread. We all know void is a great skin, visually pleasing and feature packed.
    No argument there.
    But the same thing that makes it visually pleasing is what makes it, shall we say, hard to read in daylight conditions on anything less than a high dollar "transflective" screen. Shades of grey, translucent grey overlays, and less than the highest contrasting colors (the skin is pretty close to one big collection of shades of grey). There's just not enough lumens getting out of the LCD and the CR of the colors isn't enough for high light conditions.
    If you read back, I was making a skin in pposite colors, but it's just too difficult given the current images. And as LS has stated before, it looks "washed out".
    So I took a different tack. And here it is:
    First, copy your LSX folder in the skin directory, then paste it in the same location. Call it "LSX 3.0 Day" or whatever you wish.
    Next, paste the files below into the folder. It should ask you to overwrite the existing files. Save the image to your new skin folder and call it MENU EMPTY. png. Save the next image to the dsame file and call it MENU_OFF. png. You will need to change the MENU.TXT file to MENU.SKIN or it won't work!
    Then, select a background that is white. You can either make just a white image in PS, or a picture that uses mostly white (or any other shade of white, it just should be bright).
    Lastly, define this new skin as you day skin in RRconfig.
    You're done! Check it out and see what you think. It's not perfect, but the colors are tweaked enough to give the best contrast available (black and white).
    This was just a quick job, I'll repost as I refine the image.
    Rapid share downloads for the png's:
    http://rapidshare.com/files/130380839/MENU_OFF.png.html
    http://rapidshare.com/files/13038190...EMPTY.png.html
    Cheers
    Attached Files Attached Files
    Leonardo Da Vinci
  3. #2803
    May 2007
    Another .png for you try!
    A littel bit more day visability...................but beginning to loose the "LSX feeling" again.........
    Leonardo Da Vinci
  4. #2804
    Low Bitrate Twinsen's Avatar
    Apr 2006
    Memphis, TN
    I will give this a try!
  5. #2805
    May 2007
    Quote Originally Posted by Twinsen View Post
    I re uploaded teh menu_off.png in the second post. I originally left the white fill layer in the picture which effected transparancy. The new .png fixes that .
    Cheers
    Leonardo Da Vinci
  6. #2806
    May 2007
    Hmmm, it appears the forums won't allow me to attach a .png file without turning it into an actual picture.
    You need the file instead of a copy of the picture.
    PM me an email adress if you want the file, otherwise the transparency layers won't work...........
    *EDIT* I'm going to upload the files to a free file share. Please, No more PM's!
    I'll post the link when it's up.
    Here's a quick pic of what mine looks like:
    The song title scrolls across and it's caught in "mid scroll" if you think it looks off center.
    Still tweaking it..............
    Cheers
    Leonardo Da Vinci
  7. #2807
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    ok so i am using garmin mobile pc now... and this IGCONTROL2 opens everytime i go to navi... but doesnt ever close... so in a day or 2 i have like 8 of them open... :-/
  8. #2808
    Constant Bitrate slvrsol's Avatar
    Mar 2007
    so why don't u remove it from the exectbl? or even easier, just delete it.
  9. #2809
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Thanks Greatwhite, I'm going to try this!
  10. #2810
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    hey people!
    Just dropping in. Havnt had much of any time recently. So im not ignoring anyone's PM's etc, just havnt been around much. Im still making improvements to the skin, just little bit by little bit.
    Thanks to Greatwhite for taking the inititive to do what i havent had the time to do. Its pretty much exactly what i had planned for the dayskin (minus the white around the buttons) but it looks good and should make a few people happy.
    So i guess what you really want to know is , where's that update
    ... yeah i know, you've heard this before. Its comeing soon!
    someone asked if it would be by the end of this month, and while i cant promise anything, its very possible that will happen. The sooner the better, so i can start work on void 4.0 which will be rebuilt from the ground up and have an all new look etc. So im probably going to stop all updates on the 3.x series once it reaches 3.5 and then focus on ripping everything apart and redoing it.
    more later.
    beer replenishment fund
    mp3car live search
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
