Thread: Lsx Void 3.0
  1. #2811
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Smoke!
    Glad to see you're still around! I was getting worried something might have happened to you.
    4.0?
    Hmmm, what happened to "Ether"?
    I may not upgrade to 4.0, the current version is so very stable and working great (iLists and all), I just can't see the need (for me). Not to mention, I'm so familiar with the inner working in Void now, changes are getting pretty easy..........
    BUt you never know, you do such great work!
    On the white around the buttons:
    I found it was nessesary to give the buttons some definition in daylight. Just helps overall visability. Currently working on the other menu screens.................none of which wouldn't have been possible without your excellent skin to start with.
    Cheers
    Leonardo Da Vinci
  2. #2812
    May 2007
    Download for day skin changes added to post above.
    Lsx Void 3.0
    Enjoy!
    Leonardo Da Vinci
  3. #2813
    Low Bitrate Twinsen's Avatar
    Apr 2006
    Memphis, TN
    Quote Originally Posted by greatwhite View Post
    Lsx Void 3.0
    Enjoy!
    Not sure what I'm doing wrong here, but sometimes the skin will show as in your example with the white background showing. But after restarting a couple of times, it will like slowly remove all the changes I make to make it the "day skin".
  4. #2814
    Apr 2006
    Memphis, TN
    Ah, nevermind, I guess its because you don't have the other layouts configured as your example, correct?
  5. #2815
    Newbie Nickman's Avatar
    Dec 2007
    Atlanta
    I'll be trying your day skin variant, GW. As much as I would like a transflective this makes more sense. Thanks
    Planning (0000000000) 100%
    Purchase (0000000000) 100%
    Fab/Install (000000000-) 95%
  6. #2816
    May 2007
    Quote Originally Posted by Twinsen View Post
    Most likely...........
    I only have the main screen done right now. I'm slowly reworking the other menu's.
    BUt don't hold your breath, I do have a day job after all.............
    Leonardo Da Vinci
  7. #2817
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Quote Originally Posted by liquid_smoke View Post
    hey people!
    Just dropping in. Havnt had much of any time recently. So im not ignoring anyone's PM's etc, just havnt been around much. Im still making improvements to the skin, just little bit by little bit.
    Thanks to Greatwhite for taking the inititive to do what i havent had the time to do. Its pretty much exactly what i had planned for the dayskin (minus the white around the buttons) but it looks good and should make a few people happy.
    So i guess what you really want to know is , where's that update
    ... yeah i know, you've heard this before. Its comeing soon!
    someone asked if it would be by the end of this month, and while i cant promise anything, its very possible that will happen. The sooner the better, so i can start work on void 4.0 which will be rebuilt from the ground up and have an all new look etc. So im probably going to stop all updates on the 3.x series once it reaches 3.5 and then focus on ripping everything apart and redoing it.
    more later.
    is there a possibility of adding the media plugin into the next release?
    Also what happened to ether? or is 4.0 ether
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  8. #2818
    Jul 2008
    Few questions
    First off im really sorry of someone asked this question before me, but i swear i read as much as i can and i used and i couldn't find what i wanted...
    My questions are:
    1. In the video it shows that someone is scrolling through the songs kinda like how you scroll in an iphone "springy". When I installed the skin and tried to do that, what would happen is that it would start the gesture recognition, so i took gestures off from the rr.ini....still, no help....i later realized that in one of the pictures in the "Manual" folder, the list looked different, i searched some more and found a flash file in the skin that looks the same....i tried inserting that flash file using the skin editor and that didn't work.
    so, can someone please explain to me how to make it so that it would scroll through the songs like it does in the video?
    2. Also in the video, it shows in the same screen as the one below, it shows the album art of the song, and also shows songs that (im guessing) are from the same album, or at least that are in the playlist. As you can see below, the skin doesn't display the album art, nor does it show, what songs come before or after, or other songs in the same album. (ps, yes I have the full album where this song is from, and the album art, and i have other songs in the playlist as well, just to test.)
    3. Another issue im having, is with the rating. When i rate a song, say 4 stars, it will show that it is 4 stars throughout its playing the song, the second the song is done or i skip to another song, the rating disappears, its like i haven't assigned it a rating at all.
    4. As I try and use the notes program embedded in the skin it would always trigger the gesture recognition software, so i could do nothing but shut gestures off...Is there a way to make it work with gestures on? I read somewhere that you could mark certain areas on any screen and make it so that it doesn't look for gestures, so would it work if i just give it x,y co-ordinates, or would it not work because its a flash file?
    5. This is not exactly a problem but i think it would be great if i knew how to make it work. As i was looking through the flash files in the skin, i noticed a coverflow program, so I wondered if anyone knows how to make that work in the program that would be great.
    Thank you everyone, although i have signed up until now, iv been reading up on this website for a loooong time, and i really have been learning a lot.
    PS. this is a SIIICK skin, good job liquid_smoke
  9. #2819
    Apr 2006
    Memphis, TN
    What is it exactly that you're modifying in the code? Maybe I can help. I have a day job where I sit on my *** all day and maybe do about 30 minutes of actual work.
  10. #2820
    Apr 2006
    Memphis, TN
    Quote Originally Posted by vvMINOvv View Post
    My questions are:
    Do you have the latest version of flash?
    [url=http://www.mp3car.com/vbulletin/vbimghost.php?do=displayimg&imgid=6946][/url
    You have to change the Main Menu Layouts / Vis Options. Open the Options, and click on Personalize, then Main Menu Layouts. Here you can select the mode you're looking for.
    Not sure on this one, although I think I have noticed that sometimes it takes about a minute for it to actually apply the rating, so I dunno.
    No clue on this one, I've been too lazy to even remove the gestures myself.
    There's no coverflow that's built specifically for this skin, but you might be able to embed one that has been made for other skins.
    No problem!
    Yep.
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
