For no apparent reason when my car computer woke up from sleep LSX Void looked like the attached picture. All the buttons are reset to "audio" and the colors are all messed up!
Any suggestions aside from reinstall?
. Q: The main screen is awesome. How come the other two screens (the left and right arrows on the main screen) are blank?
A: "...the idea is that those 2 screens are not the main screen, but extensions of the main menu...If you want to make those 2 screens the same as the main menu, its not hard to do at all. The only difference between them is just the lack of the items in the middle of the screen. You can just copy and past(e) them from one screen to the other using the RRSkineditor."
hi, do anyone have step by step instructions on how to make the other two screens look like the main sreen using Skineditor?
2009 Scion XB
Mac Mini Intel Core Solo
RoadRunner w/LSX Void
I dont know exactly why this happens, but I also get this if I have to hard-off the PC or if it crashes. Im guessing its some kind of data corruption that occurs to the Void files/directory. I fix it by renaming the corrupt Void directory, installing Void again and then copying over some of the old files that I had specifically setup my own way.
Hey everybody i have a couple questions, i tried searching a bit but couldnt find an answer.
1st. The text that scrolls when playing a song on the mail screen (name of song etc) is a bit cut off at the bottom, is there a way to fix this? As is the same for some button..like the text CALENDAR on the button parts of the c and r dont fit.
2nd. I saw this question asked b4 in this thread, but didnt see an answer, can u have the vis always on, on all screens.
thanks for the help
Props to smoke for the best skin of any frontend, its the only reason i stick to RR
also for some reason things look a bit slant to me, as if it is italic but its not just text..the play buttons and the line in the middle also
[IMG][/IMG] heres a screen cap
Edit: Deleting the lsx font fixed the italic issue
Edit: Fixed the text not fitting by lowering the dpi back to 96, now everything is perfect
I have updated this..
Garmin RR: Overlay and OSK for GMPC Updated 11/09/08
I finally have the majority of all my components going and im trying to tie up a few loose ends. I believe that most of these are skin related, if not please point me in the right direction.
1) Playlists - Whenever i go to Library and add music to the list i go to the playlist screen and try to save it. I can never see it after i save it to bring it back up. If i change from preset 1 to preset 2 then back to 1, all of the music is gone.
2) Radio - I have HD radio working fine with the skin. I can tune but i cant get it to go to HD sub stations. I also cant get the band to change.
3) Wireless Sync - Im looking for a way to sync my music and videos wirelessly when i pull in my drive way.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Can I chang other language osk? I use Thai language.
