I'll try that and let you know how it goes.
Printable View
http://www.mp3car.com/vbulletin/imag...6880ddd86e.jpg
I had some questions about editing some things on the skin.
1. I was wondering if it's possible to edit this so that it shows both the Artist and the Title, but not also set everything to show that way. (I know there is a ID3 playlist option, but that sets everything to use it) Is there a way to customize this?
2. I was wondering if there is a way to change the format of these numbers - for example have "03 - " instead of "3."?
3. This displays "repeat", "shuffle", and "shuffle". I would like to edit this as well, any way to do that? I'd like to because I'd like it to say "both" or something like that instead of shuffle again (when shuffle and repeat are selected).
4. Wondering once more if this can be changed to MPH? Just a format thing, not a big deal, but was wondering if it could be done?
Thanks for any help :peace:
How good are you with skin editor?
on 4. you can make the GPSSPD label smaller so it only shows the number then put a label with the word "MPH" right next to it.
Thanks, I'll give that a try.
I haven't actually used the skin editor. The one included with RideRunner correct? I can use that then to change that stuff? I'll have to give that a shot if so...
Appreciate the tips :)
Oh!
Is there a way to have visualizations come back on automatically when you come back from the library or browser? Currently I have to turn them back on manually.
Thanks!
Edit: Ok so I see it is supposed to come back on automatically, because if I select Winamp, they come right back up... so something is not letting the visualizations show through. Any ideas?
The visualization are always on when you go from screen to screen, but you how to get the visualization window re-focus by hitting selecting a non button. In other words, if you move from the Main screen to the audio screen, I would tap to left side where a button doesn't exist to have the visualization layover RoadRunner. Does that make sense?
