Thread: Lsx Void 3.0
  1. #3011
    Constant Bitrate Startingline13's Avatar
    Nov 2007
    Long Island, NY
    I'll try that and let you know how it goes.
  2. #3012
    bmo
    bmo is offline
    Low Bitrate bmo's Avatar
    Feb 2005
    ohio
    Quote Originally Posted by TxAxZxZ View Post
    I recently updated to the new RideRunner and now have problems with Void 3.301. After install it will work fine for a few days. Then, when I turn on the pc, I get a pop-up message from void asking me if I want to take a guided tour. After I click on the pop-up, all the changeable buttons turn to "Audio." It's happened about 5 times now (after un-installing and re-installing). Here's a break down of my system to better understand my problem.
    - 30Gb SSD SATA HD partioned into a 5GB (operating system) and 25Gb (media). The 5Gb partition is non-writeable (unless I disable it) and the 25Gb is writeable.
    - The OS is Windows XP with minlogon and EWF. I installed Winamp, RideRunner and iGuidance 4.0 onto the writeable 25Gb partition so I can save where I left off with my music and save my favorite destinations and POIs on iGuidance. They are located at D:\Program Files\ and RR Config is setup to look at this directory for them.
    Software/driver setup:
    - Winamp 5.13
    - RideRunner 3/01/09
    - LSX Void 3.301
    I'd hate to lose this skin as it is my favorite. But if I can't resolve it, then I have no choice but to scout out a skin that is close to this setup.
    Has anyone else ever had issues with all the buttons changing to "Audio"?
    Same problem here... Not sure what happend it was fine for a month. Than turn it on one day and pow!!! all audio tabs. Sucks because i had it all setup to my liking now i have to remember how it was setup...
    Bmo
  3. #3013
    Low Bitrate raphizzz's Avatar
    Brussels - Belgium
    Quote Originally Posted by greatwhite View Post
    Hi LS.
    would it be possible to have ls 3.0 use videolan as the video player instead of MPC or at least have it as an alternative? Or is that more of a RR thing?
    I ask because vlc is freeware, open source and plays just about every media format out there. It's very versatile and I've yet to find something it won't play regardless of format or codec required.
    Check it out if you haven't heard of it yet (no I don't work there):
    http://www.videolan.org/
    Cheers
    Is it still impossible to get VLC running in this great skin instead of MPC?
  4. #3014
    Constant Bitrate b3tts32's Avatar
    May 2006
    Arlington, Tx
    Quote Originally Posted by raphizzz View Post
    It's possible and I believe there is a plugin out there, but with the codec mpc can play all formats as well.
  5. #3015
    Jul 2008
    Questions
    I had some questions about editing some things on the skin.
    1. I was wondering if it's possible to edit this so that it shows both the Artist and the Title, but not also set everything to show that way. (I know there is a ID3 playlist option, but that sets everything to use it) Is there a way to customize this?
    2. I was wondering if there is a way to change the format of these numbers - for example have "03 - " instead of "3."?
    3. This displays "repeat", "shuffle", and "shuffle". I would like to edit this as well, any way to do that? I'd like to because I'd like it to say "both" or something like that instead of shuffle again (when shuffle and repeat are selected).
    4. Wondering once more if this can be changed to MPH? Just a format thing, not a big deal, but was wondering if it could be done?
    Thanks for any help
  6. #3016
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    How good are you with skin editor?
    on 4. you can make the GPSSPD label smaller so it only shows the number then put a label with the word "MPH" right next to it.
  7. #3017
    Jul 2008
    Thanks, I'll give that a try.
    I haven't actually used the skin editor. The one included with RideRunner correct? I can use that then to change that stuff? I'll have to give that a shot if so...
    Appreciate the tips
  8. #3018
    Jul 2008
    Oh!
    Is there a way to have visualizations come back on automatically when you come back from the library or browser? Currently I have to turn them back on manually.
    Thanks!
    Edit: Ok so I see it is supposed to come back on automatically, because if I select Winamp, they come right back up... so something is not letting the visualizations show through. Any ideas?
  9. #3019
    Oct 2007
    Quote Originally Posted by Maegnas View Post
    Oh!
    Thanks!
    The visualization are always on when you go from screen to screen, but you how to get the visualization window re-focus by hitting selecting a non button. In other words, if you move from the Main screen to the audio screen, I would tap to left side where a button doesn't exist to have the visualization layover RoadRunner. Does that make sense?
  10. #3020
    Oct 2007
    Thanks for any help
    You definitely need to pick up the Road Runner skin editor. The main screen is menu.skin, and you easily customize the labels from there.
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
