Thread: Lsx Void 3.0
  1. #3081
    Jun 2008
    I searched this thread for background and didn't find my answer. I have the RRconfig set to the backgrounds folder but when I go threw the setting in lsx void to the background page nothing shows up, if I hit the browse button it does nothing and if I hit the "more" button then RR locks up. What have I missed?
  2. #3082
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by mdawg View Post
    A few pages back, BlueZX3 posted some updated files that need to ovewrite some old ones that don't conform to the new RR. That might be it.
    Start to go back page by page from here and you'll find it.
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  3. #3083
    Jun 2008
    Nope, not it. Nothing still shows up and RR still locks up when I hit the more button.
  4. #3084
    Sep 2006
    War-Town, GA.
    Then make sure Flash 10 is installed correctly (from the sticky in the RR forum IIRC)
    OLD SYSTEM (DEAD)
    M2-ATX Power Supply
    Windows XP SP3
  5. #3085
    Jun 2008
    It is...
    This is all that comes up when I hit the background button, as you can see by the window box around RR I had already hit the more button resulting in RR locking up. If I hit the browse button in the top right nothing happens either. RRConfig is set to the correct folder for backgrounds as well.
  6. #3086
    Mar 2004
    Anyone by chance of a copy of the System-Manager hosted any where? All the links Ive found are dead.
  7. #3087
    FLAC djmickyg's Avatar
    Feb 2004
    Quote Originally Posted by JoseJag View Post
    And how do you install the font manually?
    Turn on No internalizatoin in the RR config to fix the font issue
  8. #3088
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    It is...
    I've been using carwings for a while, decided to try LSX again...I miss the playlist feature a lot!
    I had the same issues, even after updating with bluezx3 files on page 204. I couldn't press the button to show the next screen.
    I uninstalled LSXvoid, installed 3.3, then the 3.301 update, then the bluezx3 update on p. 204. Now I have these issues solved, but I still see the numbers 7 and 8 and some other font issues.
    Now I have to figure out which font is it, and reinstall it, not sure it's worth searching all these pages, if the fresh reinstall didn't solve it, I'm afraid it might be something deeper.
    I'm afraid this skin is dead already and it won't keep up with RR monthly updates, sadly.
  9. #3089
    Feb 2004
    read my post above
  10. #3090
    Feb 2004
    I've made something live been wanting to do for a while, make a day skin. it helps aloe with glare
    To use it, download the file here http://www.megaupload.com/?d=QL93PZ2Y
    then make a copy of the existing LSX folder and rename it to something like "LSX VOID 3.0 Day" then extract the downloaded file into it and overwrite the files. and it should work.
    note the skin settings are stored in the skin.ini so if any changes one made in one, this file can be copied over to match the selling in the other
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 01:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 12:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 09:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 01:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 07:00 AM
