Page 32 of 318 FirstFirst ... 22232425262728293031323334353637383940414282132 ... LastLast
Results 311 to 320 of 3172
Thread: Lsx Void 3.0
  1. #311
    Raw Wave
    Jun 2002
    Virginia
    First off, really, really nice skin, LS! I am definitely going to be switching back and forth between JohnWPB's DigitalFX skin and this one. Thanks for all the hard work.
    A couple of things:
    1. The only issue I'm having at this point is that I don't see the logo, compass or speedometer. I have selected them in the settings screen, but nothing show ups. I know I have the appropriate Flash installed because it all works fine in the DigitalFX skin. Any thoughts?
    2. Where do I put the spectrum analyzer files that you recommended downloading at the beginning of this thread?
    3. I'm hoping you'll consider adding DJiK's Jump to Plugin once he rebuilds it in a month or so.
    Thanks again for all the hard work. Donation is on the way.
  2. #312
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by kbreeden View Post
    A couple of things:
    funny you say that, me and John talk every day and you should see some pretty cool stuff from the both of us in the near future.
    1. only the logo and compass is flash, the speedo is just a label. For the speedo to work you have to first use a gps com port splitter so RR can connect to your gps device at the same time as your navigation app. Do a search on this site for an app called xport.
    For the flash issues, im not sure why you would see absolutely nothing, i know the files are there and others have them working or working but with flash issues till they upgrade flash. But to see nothing is kind of odd. Even if your flash was broken you would see something.
    Which menu option are you using?
    Have you tried to replace the logo with one of your car? If so did you make sure the file name was correct? The logos should be named clock.swf anything else will not show up.
    2. Those files are winamp visuals, they go into
    winamp\Plugins\avs
    3. already on the todo list
    beer replenishment fund
    mp3car live search
  3. #313
    Registered User vfinterceptor's Avatar
    Oct 2005
    up-the-hill-turn-left-by-the-big-tree
    Quote Originally Posted by Miles View Post
    With liquid_smoke's approval, here is my attempt at providing skin(s) for Microsoft Streets & Trips 2006.
    The attached zip contains 4 files:
    GPS_Streets1.skin
    Skin with streets app in the middle, surrounded by the commonly used buttons. By clicking on the 'FS' button in the top, it loads GPS_Streets2.skin.
    GPS_Streets2.skin
    Skin with streets app larger, covering up the top buttons. By clicking on the 'FS' button in the top, it loads GPS_Streets3.skin.
    GPS_Streets3.skin
    Skin with streets app filling entire screen except time, song title and 'FS' button. By clicking on the 'FS' button in the top, it loads GPS_Streets1.skin.
    GPS_Streets_POPUP.skin
    When using Streets1/2/3.skin, clicking on the 'MENU' button will open up this popup screen with a few more additional buttons.
    Here are the settings I've added to Exectbl.ini within both the day and night version of the skin:
    These skins use the existing images in LS latest release of the skin, so no need to add anymore jpg's.
    Feel free to customize as you see fit, and a huge kudos to LS again for making such a well laid out and designed skin.
    Hi Miles,
    I hate to admit it, but I just can't get this to work properly. I've been massaging it for a couple days now, off and on. I have to tip my hat and ask for a little spoonfeeding.
    I can get s&t 06 to open in lsx fine, but there are no buttons or skins. S&T simply runs in the nav window as "Bill's Boys" designed it.
    I put the exetbl.ini file in day and night (cut and pasted from your post) and put a copy of all 4 skins in both day and night. Was this in the wrong spot?
    I also can't seem to figure out what I am suppposed to edit with the "ap03", "gps4" line. I can find it, just not sure what to do with it.
    I'm feeling pretty stupid here, please be kind.
    I'd really like to get this to work as you have it. It works the way it is, but I would like a more integrated feel. I prefer S&T to iGuidance for my uses. Sure wish S&T was easier to customize though!
    Cheers
    BJ
  4. #314
    Newbie Major_Disaster's Avatar
    Oct 2006
    Suggested addition to post #1 of LsxVoid 2.0
    LS,
    Great skin.
    You might want to make a modification to post #1 to include the codec (Lsx Void 3.0) that is necessary for your skin. I had downloaded the skin in preparation for an install this weekend. I suddenly realized that I remembered reading about an additional codec and searched through the forum for it.
    Again, thanks for all your hard work.
  5. #315
    Sep 2005
    I would find it difficult if the XM radio would run, not allowing me to use the navigation/any other feature... Is that what you mean? I very often check nav/sensors/do other things while listening to the radio...
  6. #316
    Jan 2007
    Looks very great!
  7. #317
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by liquid_smoke View Post
    1. only the logo and compass is flash, the speedo is just a label. For the speedo to work you have to first use a gps com port splitter so RR can connect to your gps device at the same time as your navigation app. Do a search on this site for an app called xport. For the flash issues, im not sure why you would see absolutely nothing, i know the files are there and others have them working or working but with flash issues till they upgrade flash. But to see nothing is kind of odd. Even if your flash was broken you would see something.
    All is now working. Thanks.
  8. #318
    Aug 2003
    Chicago
    Quote Originally Posted by Major_Disaster View Post
    LS,
    Great skin.
    The codec is just for the demo video, its not required for the skin to work etc. But i should prob put a link on the download site to where you can get the codec for the video.
    mp3car live search
  9. #319
    Variable Bitrate CARLOS_CET's Avatar
    Aug 2004
    NH
    So I noticed one thing, might just be me. When I go into the AUDIO screen the ratings stars come up as they should (4 stars can be seen for a song that has been rated with 4 stars. When I go into the AUDIO old screen, the stars do not appear. Has anyone else seen this?
    One thing I miss from my older version of LSX Void is the delete plugin that I setup. Can I use the old delete plugin on this skin or is there a better way to do it?
    Car PC Progress
    (>>>>>>>>>>>>---) 90%
    "Don't speak about it, be about it"
  10. #320
    Oct 2006
    Codec confusion cleared
    Ah.....very good.
    Thanks.
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
