Page 33 of 317 FirstFirst ... 23242526272829303132333435363738394041424383133 ... LastLast
Results 321 to 330 of 3166
Thread: Lsx Void 3.0
  1. #321
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by CARLOS_CET View Post
    So I noticed one thing, might just be me. When I go into the AUDIO screen the ratings stars come up as they should (4 stars can be seen for a song that has been rated with 4 stars. When I go into the AUDIO old screen, the stars do not appear. Has anyone else seen this?
    One thing I miss from my older version of LSX Void is the delete plugin that I setup. Can I use the old delete plugin on this skin or is there a better way to do it?
    ill take a look at the AUDIOold screen stars.
    what is the delete plugin?
    EDIT: Just took a look at the AUDIOold screen and the stars show up fine for me. Have you fiddled with the ratings plugin in anyway, updates?
    beer replenishment fund
    mp3car live search
  2. #322
    Variable Bitrate CARLOS_CET's Avatar
    Aug 2004
    NH
    I haven't done any changes with the ratings plugin. One thing I forgot to mention is that it happened with the day skin. I'll have to see if I get the same thing with the night skin.
    Here's the link which talked about the delete plugin... Could i get help with a custom delete button?
    Car PC Progress
    (>>>>>>>>>>>>---) 90%
    "Don't speak about it, be about it"
  3. #323
    Aug 2003
    Chicago
    ah, you just want a delete button, threw me off when you said plugin.
    humm, i though i added something for this a while ago, i must of forgot it or something cuz i cant find it in the skin now. Not really sure where i would stick the button either when i look at the screen, its pretty full right now.
    What I could do is add it as an available command in the custom button command list then you can customize one of the buttons in the audio player to delete files.
    mp3car live search
  4. #324
    Aug 2004
    NH
    Quote Originally Posted by liquid_smoke View Post
    That would be really cool. I just dump full albums on my carpc and sometimes I want to delete some songs that I don't like so it would be really cool to have there. I appreciate it.
    Car PC Progress
  5. #325
    May 2006
    Houston
    Current Song Doesnt Change
    For some reason when my playlist goes to the next song my screen doesn't update. The old song that was playing is still highlighted. The only way to get it to update is to exit the screen to another or skip to the next song. It happens on any screen that shows the playlist.
    My visualization is displaying about 50 pixels too high, it is covering the top buttons but appears to the the correct size otherwise. Where do I go to tell it to lower the X position so it fills the middle of the skin?
    Any suggestions?
    -Gk
  6. #326
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Gurukarma View Post
    For some reason when my playlist goes to the next song my screen doesn't update. The old song that was playing is still highlighted. The only way to get it to update is to exit the screen to another or skip to the next song. It happens on any screen that shows the playlist.-Gk
    RRConfig.
    Check - Highlight current playlist song on change
  7. #327
    May 2006
    Houston
    Quote Originally Posted by Enforcer View Post
    RRConfig.
    Yeah go figure. Found it right after I posted the message, logged in to edit the post and you already replied Thanks. Its amazing the toggles I find in the config even though I've been using it over a year now - I guess it was always on by default until now.
    -GK
  8. #328
    Aug 2003
    Chicago
    also for your vis issues.
    I recent found that a certain version of the jump to file winamp plugin causes the visuals to not embed correctly and be like you said about 50 pixels off and sometime not show at all. Doesn't matter what skin your using either. I have no idea what the jump to file plugin has to do with visuals or why it would even cause a bug like that, but i bet if you recently updated that plugin or updated to a newer version of winamp that includes it you have a significantly higher change of visual issues in RR.
    I also wouldn't recommend using any higher version of winamp than 5.13
    mp3car live search
  9. #329
    Registered User vfinterceptor's Avatar
    Oct 2005
    up-the-hill-turn-left-by-the-big-tree
    streets 2007 skin
    Admittedly, this is a plagerized skin off Miles' original concept, except this uses 07 instead of 06 (easily changed if you have 06). I just find it suits my uses better. Follow Miles' instructions on page 7 (I think it was 7) to install them. What I would really like is to incorporate audio controls on this skin, workin' on it............. but it's hard stuff for a newb!
    Just trying to give back to the thread!
    Cheers
    BJ
  10. #330
    Aug 2003
    Chicago
    cool, thanks for sharing.
    screenshots?
    mp3car live search
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
