Page 34 of 317 FirstFirst ... 24252627282930313233343536373839404142434484134 ... LastLast
Results 331 to 340 of 3166
Thread: Lsx Void 3.0
  1. #331
    Constant Bitrate rigg419's Avatar
    Apr 2006
    Behind the Orange Curtain
    finally got the skin working today (actually, finally got rr working today and the skin along wih it)
    I forgot how dfferent rr is from cf. I'm sure this skin makes that feeling of being confused more pronounced, kind of like using mac os9 then going to xp, and then osx. familiar, sort of the same thing you remember except way better (even though I have only like 5% of it figured out so far.
    contributed a bit to the beer fund (i'm poor right now, but still, it's the first time I ever gave someone money for a skin. It's that good.)
    Anway, LS thanks for the awesome skin/front end platform
    Oh, is there a way to get rid of the "good night " greeting, it's probably been covered, but I'm only through about 10 or 11 pages in this thread so far
  2. #332
    Registered User vfinterceptor's Avatar
    Oct 2005
    up-the-hill-turn-left-by-the-big-tree
    Quote Originally Posted by rigg419 View Post
    Yup, keep reading.
    Well, at least how to change it.
    Cheers
    BJ
  3. #333
    Sep 2005
    XM Update:
    So, the only way that the XM will shut off is by loading the audio skin, then pushing the "Library" button. Any ideas why this is? Is there some way that I can add whatever procedure it's loading onto pressing the "audio" shortcut or perhaps the playlist switching buttons??
  4. #334
    Nov 2004
    St Louis
    Quote Originally Posted by fewman View Post
    XM Update:
    Mine shuts off anytime you select another audio device, i.e., audio, FM, TV, DVD, video. It will keep playing on others: main, gps, gas, internet, etc.
  5. #335
    Sep 2005
    This is very odd... what settings to you have checked in the config??
  6. #336
    Sep 2005
    So I've figured out that when I use the new Audio button, it works properly... however, using the "old Audio" does not... I'm wondering what the difference is. Also, I have some auto playlist buttons for loading my CD/other playlists and they don't shut off the XM (so both are playing simultaneously). Is there some code I need to add to the loading playlist button? Is there some way I can get it to jump to the audio screen when the playlist is loaded (and hence shutting off the XM)?
  7. #337
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    yeah, i think i see the problem with the AUDIOold screen, its not named audio_player.skin i think its named something else. Ill probably have to make it an option similar to the main menu options, so it will require a reload when chooseing it, instead of how it is now you can actually have both of them available. To be honest, i really dont see any reason to use that version of the audio player unless you are absolutely in love with seeing the album art on that screen.
    A temp fix for those stuck on using the old audio player, go into the skins folder and rename audio_player_old.skin to be audio_player.skin. Note audio_player.skin already exist (its the new version) so just basically swap names of the two files but dont name either of them some odd name.
    For the playlist you have, this issue is likely related to using the old audio player, since its not stopping xm on that screen unless you go to library. Loading a playlist wont stop xm ect. The above temp fix should also fix this issue.
    also, how are you loading the playlist? You say is there some way to get it to jump to the audio screen when you load a playlist, but you should already be in the audio section to even load a list. Do you have them tied to a shortcut?
    beer replenishment fund
    mp3car live search
  8. #338
    Aug 2003
    Chicago
    Thank you very much.
    To remove the welcome messages. Open ExecTBL.ini thats located inside the skins folder (day version and night version).
    Find and edit the line of code below
    before
    Code:
    "LSONSKINSTART","ratecheck2||RUN;LSTOOLS\welcomeMSG\welcome.exe"
    after
    Code:
    "LSONSKINSTART","ratecheck2"
    i should prob make this an option you can turn on and off from inside the skin.
    mp3car live search
  9. #339
    Newbie Eugene120's Avatar
    Mar 2006
    Moscow/Russia
    LS, you could also make a note on one of the fist pages 'bout the "No Internationalization" option in the RRconfig for cyrillic and other non-english users, since this question has already been asked here a couple of times...
  10. #340
    Nov 2004
    St Louis
    The difference is the old one isn't renamed to "Audio.skin." The skin names are important in RR for automatically switching audio sources. For your auto playlist buttons, try preceeding the command with "Audio;" which will switch to the audio skin first and then execute the rest of the command line.
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 01:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 12:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 09:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 01:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 07:00 AM
