Page 39 of 318 FirstFirst ... 29303132333435363738394041424344454647484989139 ... LastLast
Results 381 to 390 of 3172
Thread: Lsx Void 3.0
  1. #381
    Jun 2006
    Seattle
    Quote Originally Posted by liquid_smoke View Post
    ill have to look into it, i havnt actually used the speedo on the clocks for ages, but they should just work. It gets the data from gps speed label at the top of the screen.
    thanks for looking into it
    95 Mustang GT + Mach 460 Audio
    Lilliput EBY701 7" TS LCD w/ 4-way arm
    BU353 USB GPS
    iGuidance 3 + Road Runner + LSX Void2
    200W Inverter
    Intel Core Duo 1.6GHz T2050, 1GB DDR2, 80GB, DVDRW
  2. #382
    Constant Bitrate venealis's Avatar
    Apr 2006
    Richmond, VA
    little more specific, there are a bunch of ig add ons.
    Sorry about that right now i can't be to specific not at my computer. But its the add on for displaying the iGuidance next turn on other screens. ie turn left on left street. will show this information on lets say the main screen.
  3. #383
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by venealis View Post
    Oh ok, i know what you mean.
    I did have intentions of having this working, and i believe its still setup to work but it never actually did work for me and i just gave up on it. It would never pull the direction icons from IG and im not sure if anyone else got it to work either.
    beer replenishment fund
    mp3car live search
  4. #384
    Newbie Major_Disaster's Avatar
    Oct 2006
    Questions about general.ini
    I have am almost ready to deploy my car pc. The only problem (and it is small) is that the autoswitch from day skin to night skin is not working.
    I was looking at the general.ini file:
    ApplyToVideo=False
    ApplyToVisu=False
    AutoSwitch=False
    DayTime=8:00:00 AM
    NightTime=6:00:00 PM
    If I understand the the above section of the ini file, it should be set to True and if I want day/night options to carry over to video and visual, they should also should be set to True also.
    Is this correct?
  5. #385
    Aug 2003
    Chicago
    im not actually sure what hte applyto video and visu lines are for or what they do.
    but to get it to work, you have to set Autoswitch=True
    and also in RR.ini set something else, i believe the same line. I cant check now.
    mp3car live search
  6. #386
    Oct 2006
    rr.ini
    Thanks for the input. I don't see an Autoswitch=True entry in my rr.ini file but I will look through the other ini files.
    Again,
    Thanks.
  7. #387
    Jul 2006
    Connecticut
    i just spent the past hour reading through this single thread not only because I love this skin, but because I can't seem to be able to use any of the other layouts on page 2 of the options. Whenever I pick anything such as big vis, RR jumps back to the main screen but just gets stuck. none of the buttons have text and the speed label shows the label code.
    After I shut down RR, I have to delete resume.ini and rr.ini to get RR to run again after this happens. If I don't, the Alpine skin somehow gets injected into resume.ini and then RR says it can't find Alpine. This is kind of odd since I've never installed the Alpine skin on this machine.
    I thought it may have been flash so I updated to 9. Nada. So I have just left it at the default layout although I'd like to run the visuals that are displayed on the first few posts in this thread.
    Any ideas?
  8. #388
    Oct 2006
    Autoswitch blues
    Well, I looked through all the setting and saw no other place to set the autoswitch except in in the general.ini files that are included with each skin. I made the necessary changes but it still won't auto switch.
    I am not going to stress over it. It is probably something related to my individual setup. I can always switch manually.
    Quote Originally Posted by Major_Disaster View Post
    Again,
    Thanks.
  9. #389
    Aug 2003
    Chicago
    Quote Originally Posted by MycoDeX View Post
    Any ideas?
    somehow your settings are screwed up fror the skin.
    Either in the root of your RR install or maybe inside the skins folder is a text file name LSX_ADDTORR.ini.txt or something to that effect.
    Open your RR.ini and make sure you have the correct settings for the skin.
    I think there is a link to the file somewhere on the first few post.
    If you still having problems, try to install the skin again on a fresh install of RR or delete rr.ini and reinstall the skin.
    mp3car live search
  10. #390
    Jun 2006
    Seattle
    I used the flash speedo clock on another skin, and it worked perfectly.
    I dont know why the same speedo doesn't work here.
    Could it be the fact that the other skin I used it with, did not have a Speed label in the skin, like the one you have on the top center ?
    If yes, what could I do to have them both work simultaneously?
    BU353 USB GPS
    200W Inverter
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
