Page 4 of 317 FirstFirst 123456789101112131454104 ... LastLast
Results 31 to 40 of 3166
Thread: Lsx Void 3.0
  1. #31
    Variable Bitrate marazi's Avatar
    Dec 2005
    Skien, Norway
    Quote Originally Posted by liquid_smoke View Post
    works fine for me under Vista. You may have to turn off uac or give the installer permission to copy files. Not system files are copied or modified etc, on xp or vista.
    what errors are you getting when running the installer on vista?
    ok... no errors... it starts, but stops at 1%... i did run the installer on my xp box without any probs, so i got the skin workin... love it
  2. #32
    FLAC djmickyg's Avatar
    Feb 2004
    Quote Originally Posted by Gixxer View Post
    Alright, stupid question. How do I get the forecast in areas other than Chicago?
    Awesome work by the way!!
    "Weather Forecast videos from google inside the weather screens. To change the city from Chicago, edit "LSXCOLORS.txt". At the end of the file you will see a bunch of cities listed. Change the first line in this section to the city you want, only the url should be editied."
    read LS's first post!
  3. #33
    Sep 2005
    Mexico
    I just installed this skin on my car, but I couldnt get it to work at first, the menus wouldnt appear correctly (like if the rr.ini was incorrect) after doing some tests, i found out that there was a exe script running on background that hanged (ratecheck.exe) If i manually stopped that exe then it loads the menus as specified by the .ini (default one). For now I renamed ratecheck.exe to ratecheck2.exe and that fixed my probs, but not quite sure what else could be cuasing this. I did a clean install on RR and then the skin install. anyone else experienced that? or it was just me??
    (RR running on a stripped down version of XP SP2)
    My current project
    Jetta 2000 MKIV
    SP13000/Xenarc 7"
    100GB / 512 RAM / GPS / Wi-Fi
  4. #34
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by Asskick View Post
    ratecheck is the ratings plugin. Did this only happen once or does it always happen. What happens when you try to run it stand alone.
    beer replenishment fund
    mp3car live search
  5. #35
    Aug 2003
    Chicago
    Quote Originally Posted by Sonicxtacy02 View Post
    curious as to how ur rating system works
    it works the way you made it
    mp3car live search
  6. #36
    Aug 2003
    Chicago
    just incase anyone else is little confused on the weather forcast,
    on line 106 of LSXCOLORS.txt is the only line you need to modify.
    By default it looks like this
    Code:
    /DEFINE GOOGLEVIDEOWEATHER "googleplayer.swf?docId=-5156785011415695281&hl=en"
    this is for Chicago forcast.
    To change it to sunny Miami it would look like this
    Code:
    /DEFINE GOOGLEVIDEOWEATHER "googleplayer.swf?docId=6890858542239244837&hl=en"
    mp3car live search
  7. #37
    Sep 2005
    Mexico
    Always does it... right now it just started doing again, i tried on my desktop pc with same results, if I kill the script from the tray, boom the screen finishes rendering (else I just get stuck with a GUI with no usuable buttons)
    and if I try to run it directly from the explorer I just get the icon stuck on the tray bar.
    My current project
    Jetta 2000 MKIV
    SP13000/Xenarc 7"
  8. #38
    Aug 2003
    Chicago
    ive never seen that happen before. Is this the first time you're using this skin or did you use previous versions also? The file in question has been used with this skin for quite a while now.
    What type of virus scanner are you using ? I know some of them have issues with autoit scripts.
    mp3car live search
  9. #39
    Feb 2004
    for some reason all my fonts have gone ITALIC not sure why?
    it inst set like this in the lsxcolors.txt and i didnt change anything?
    it was like this when i first downloaded
  10. #40
    Aug 2003
    Chicago
    none of the fonts are set to be italic, not sure how that can happen. I see your in Au so my guess is there is prob some localization issues with your version of windows and the fonts the skin uses. Which items on screen are in italic, i can try to narrow it down to which font is causing you problems.
    mp3car live search
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
