Page 40 of 317 FirstFirst ... 30313233343536373839404142434445464748495090140 ... LastLast
Results 391 to 400 of 3166
Thread: Lsx Void 3.0
  1. #391
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    the speed label is what the clock gets the info from.
    Im not sure what other skin u used these clocks with, but these clocks were made for this skin by me and Dinasty. I still havnt had a chance to look and see if they still work for me but i don't see any reason why they would just stop working.
    Ill test it out in the morning though.
    beer replenishment fund
    mp3car live search
  2. #392
    Oct 2004
    Toronto
    Quote Originally Posted by liquid_smoke View Post
    i think i know why the trip log still isnt working, ill have some instructions later on how to turn it on. It isnt the .dll though, they get registered on install.
    any work on the fix for this? This is the only thing in this skin thats not working for me that I could actually make use of.
  3. #393
    Registered User vfinterceptor's Avatar
    Oct 2005
    up-the-hill-turn-left-by-the-big-tree
    Anyone try to use video lan with this skin (or RR for that matter)?
    It doesn't seem to want to run or embed.
    Cheers
    BJ
  4. #394
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by CTS_V View Post
    I had it working earlier by running the regsvr32 service again for the dll but now it seems to have stopped again... I can go to the tripmeter page but it doesn't show any info...
    Swedish site for CarPC's
    http://www.bilpc.info
  5. #395
    Oct 2004
    Toronto
    Quote Originally Posted by Naesstrom View Post
    I'm in the same boat, except it has never worked for me. I get the page, but everything is blank except the gps position, altitude etc. nothing on the top row though.
    I'd love to use this it would be a great solution for me as I do log work vs. personal kms.
  6. #396
    Jan 2007
    A question on the rainlendar program as I'm trying to set up this skin to use in RR (I'm in demo mode of RR and MI in trying to learn/decide what front end to use).
    I went to the rainlendar link and list the old software as No Longer Supported. I downloaded Rainlendar2.
    So can this be used? Could I just change something in the RR ini from like rainlendar to rainlendar2?
  7. #397
    Aug 2003
    Chicago
    Quote Originally Posted by MMAlexander View Post
    RR does not have a demo mode.
    you can use Rainlendar2, its backwards compatible with the calendar skin i made for it. I think the only thing you will need to change is the path to rainlendar in ExecTBL.ini file found inside the skins folder.
    Open the file (ExecTBL.ini) and do a search for "rain" it will take you directly to the are you need to edit.ts
    Make sure the path is correct, i belive rainlendar 2 uses a different path.
    Thats all you need to do.
    If you are using the lsx calendar skin for rainlendar or intend to, just install it the same way you install other skins for rainlendar.
    done.
    mp3car live search
  8. #398
    Jan 2007
    Hey Thanx for the prompt reply
    I was able to get the older version of the calander and so I just used that.
    Everything seems to be working alright except for when I try and embed an application in one of the extra buttons. I have Project 64 working. I mean your skin will open the program, but the skin will say "Click and Hold Set-up Button To Pick Application To Embed" whenever I launch the program from LSX Void. No matter how many times I complete the steps, it does the same thing. I just figured it's a bug I can deal with. Not like I'll be playing the emulation too often.
    THe Note Sync program doesn't work in the skin either. I have the program in the default folder it installs from as instructed. When I click on the icons inside your skin, I get a bit of movement in the task bar area by the clock but nothng more. I can run the application just fine outside of RR though.
    When I said Demo, I meant I was demo'n them for/to myself. I've installed them both and just trying to see what I can get a handle on the best.
    Again Thank You for the response and the hard work you've obviously put into your skin.
  9. #399
    Jan 2007
    Oh yeah, one more thing I needed to ask about.
    In the first post, you list needed apps/items. I got all of them but I have no idea what I do with "VISUALS".
    I downloaded the file but I haven't clue the first as to where I'm supposed to place them ???
  10. #400
    Jan 2007
    Figured it Out. They are effects for the AVS plug-in for Winamp.
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
