1234
Printable View
I just tried 1234 and i hit the "key" icon and it just erases the password so thats not it right? And this was my first time installing the skin too with a fresh install of RR...
Yup... i even tried the "regsvr32 screenlock.dll" method in the readme but it still just doesn't do anything but erase what I wrote when I click the key.
the spectrum in my screenshots is not included with winamp. There is a link to it somewhere on the 1-3 posts. Note, it will not work with winamp 2.x you will need winamp 5.x and i recommend not going any higher than winamp 5.13, higher versions will give you problems. If you need to download an older version of winamp go to http://oldversion.com
also note the vis does not start on its own. You have to click the button on the top right corner of the screen to activate it. If you want it to start on its own everytime you load RR. Open RRConfig.exe and put VISU in the "Start Command to execute:" field.
