Page 46 of 317 FirstFirst ... 36373839404142434445464748495051525354555696146 ... LastLast
Results 451 to 460 of 3166
Thread: Lsx Void 3.0
  1. #451
    Oct 2004
    Toronto
    Quote Originally Posted by Vip3rV333 View Post
    Hey, Ive tried searching and everything but I cant seem to figure out the default password for the Lock fearture. Anyone wanna help me out?
    1234
  2. #452
    Feb 2007
    I just tried 1234 and i hit the "key" icon and it just erases the password so thats not it right? And this was my first time installing the skin too with a fresh install of RR...
  3. #453
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Quote Originally Posted by MAH View Post
    When I tried this skin, every button points to Audio. No GPS or even a way to exit roadrunner without using windows program close.
    I just had this happen as well with a fresh install of windows.
    I made the mistake of installing LSX before RoadRunner.
    I reinstalled LSX over itself after I installed RoadRunner and all the buttons worked fine.
    Just reinstall LSX and you should be good!
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
  4. #454
    Oct 2004
    Toronto
    look in the skin folder for the file "screenlock.ini" open it and voila, your PIN is there. its 1234 by default.
  5. #455
    Feb 2007
    Quote Originally Posted by CTS_V View Post
    Arg... I found that and I tried changing the pin, reading the readme for it, and even changing the command to open a different skin. None of it works...
  6. #456
    Oct 2004
    Toronto
    did you check/change both day/night folders?
  7. #457
    Feb 2007
    Yup... i even tried the "regsvr32 screenlock.dll" method in the readme but it still just doesn't do anything but erase what I wrote when I click the key.
  8. #458
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by DodgeCummins View Post
    I have a question on embedding.
    I followed the explanation on the first page of this thread, and watched the video.
    I can get all the various menus to work as I follow the directions...but when it comes time to do the "Setup"...I "browse" to the folder with the app...but it doesn't show in the list...the list shows more folders, but not the app.
    In fact...I can't even install notepad...all it shows is folders...no other files.
    make sure you add ".exe" as an audio file type in RRConfig.
    mine looks like this
    .m4a,.mp3,.wma,.cda,.aac,.rmj,.m3u,.MP4,.txt,.exe
    beer replenishment fund
    mp3car live search
  9. #459
    Aug 2003
    Chicago
    Quote Originally Posted by Naesstrom View Post
    Hey, I'm never pushy, I just missed the last 5-6 pages and speedread through them so I was just kind of wondering if I missed something about that particular problem... chill m8!
    Ye I know that part... thats where I saw it, probably in one of the big vis skins!
    the vis in that screen... it's just empty on mine, nothing there at all! and I can't seem to find any vis in winamp that looks like that spectrum thingy!
    the spectrum in my screenshots is not included with winamp. There is a link to it somewhere on the 1-3 posts. Note, it will not work with winamp 2.x you will need winamp 5.x and i recommend not going any higher than winamp 5.13, higher versions will give you problems. If you need to download an older version of winamp go to http://oldversion.com
    also note the vis does not start on its own. You have to click the button on the top right corner of the screen to activate it. If you want it to start on its own everytime you load RR. Open RRConfig.exe and put VISU in the "Start Command to execute:" field.
    mp3car live search
  10. #460
    Aug 2003
    Chicago
    i believe the correct file to edit with the pin is located in the root of your RR install, not the skin folder. There may be a copy in there too but its not the one thats used by the plugin. This may be and likely is your problem.
    mp3car live search
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
