Page 47 of 317 FirstFirst ... 37383940414243444546474849505152535455565797147 ... LastLast
Results 461 to 470 of 3166
Thread: Lsx Void 3.0
  1. #461
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Quote Originally Posted by liquid_smoke View Post
    make sure you add ".exe" as an audio file type in RRConfig.
    mine looks like this
    .m4a,.mp3,.wma,.cda,.aac,.rmj,.m3u,.MP4,.txt,.exe
    Thanks, I figured it was something simple.
  2. #462
    Mar 2005
    Sweden/Vaxjo
    the spectrum in my screenshots is not included with winamp. There is a link to it somewhere on the 1-3 posts. Note, it will not work with winamp 2.x you will need winamp 5.x and i recommend not going any higher than winamp 5.13, higher versions will give you problems. If you need to download an older version of winamp go to http://oldversion.com
    also note the vis does not start on its own. You have to click the button on the top right corner of the screen to activate it. If you want it to start on its own everytime you load RR. Open RRConfig.exe and put VISU in the "Start Command to execute:" field.
    thanks!
    At first I had some problems that the bars was just thin lines but after installing winamp 5.13 that was fixed... I still have one problem though! how can I get it to be in the background like in the screens, and how can I lower the opacity so it doesn't cover the background...
    Right now when I click the vis button it just covers everything else!
    Swedish site for CarPC's
    http://www.bilpc.info
  3. #463
    Feb 2007
    Quote Originally Posted by Naesstrom View Post
    thanks!
    Yup, I got the same problem, but I just figures that it was something with my video drivers so I didnt look into it any further.
    But now that someone else has it, is there a solution?
  4. #464
    Newbie Eugene120's Avatar
    Mar 2006
    Moscow/Russia
    Quote Originally Posted by Vip3rV333 View Post
    The same situation here...
  5. #465
    Mar 2005
    Sweden/Vaxjo
    yey! I'm not alone!!!
    (just had to... sry!)
  6. #466
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Run WINAMP standalone and start the visu. Then right click in it and select
    AVS Editor, click settings and then display. There you can adjust Alpha Blending.
  7. #467
    Jan 2007
    What is the AVS visualization used in the the Vis & Logo Options previews? The one with the bars in case you are not sure what I am talking about
  8. #468
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Open RR.ini and add this line.
    AvsTransparent=TRUE
    In the same dir you should see a file named Screensaver.ini (the name is missleading)
    Open it and make sure the settings are like below
    AvsTransparent=True
    FadeOnIdle=False
    SecondsToFade=300
    FadeInterval=10
    DefaultOpacity=175
    MaxOpacity=255
    Turning on opacity from inside of winamp will give you a transparent visual, but it will still cover buttons in RR and you will not be able to click those buttons till u turn the visu off. What the directions above does is allow you to turn the visuals on, have them transparent and also the ability to still click the buttons under the visuals so you dont have to toggle them on/off to change the volume etc.
    beer replenishment fund
    mp3car live search
  9. #469
    Mar 2005
    Sweden/Vaxjo
    AvsTransparent=TRUE
    AvsTransparent=True
    FadeOnIdle=False
    SecondsToFade=300
    FadeInterval=10
    DefaultOpacity=175
    MaxOpacity=255
    You're the man m8!
    Thanks, I just love your skin, and so does my GF!
    [edit]
    Didn't find any screensaver.ini file in my RR directory, guess it should work if I just make a new one with that info...
  10. #470
    May 2004
    Is there a way to improve the speed of the Notes in this skin? My Epia just dies when running it and I usually get jagged lines when I try to write something, even with a stylus.
    Also, what is the best way to add custom commands as buttons? In the past version, I used the extra APxx entries to make XM presets:
    "AP47","XMCHAN;8"
    "AP48","XMCHAN;9"
    "AP49","XMCHAN;20"
    "AP50","XMCHAN;48"
    "AP51","XMCHAN;54"
    "AP52","XMCHAN;81"
    "AP53","XMCHAN;113"
    "AP54","XMCHAN;127"
    "AP55","XMCHAN;202"
    "AP56","XMCHAN;212"
    But in this version, there aren't many free buttons. Do I just have to replace some existing apps with my own?
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
