Page 5 of 317 FirstFirst 12345678910111213141555105 ... LastLast
Results 41 to 50 of 3166
Thread: Lsx Void 3.0
  1. #41
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    not compatible with iGuidance 3.1
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
  2. #42
    Sep 2005
    Mexico
    Quote Originally Posted by liquid_smoke View Post
    ive never seen that happen before. Is this the first time you're using this skin or did you use previous versions also? The file in question has been used with this skin for quite a while now.
    What type of virus scanner are you using ? I know some of them have issues with autoit scripts.
    Ive used your previous skins without a prob.. as far as the antivirus no AV is running on my carpc (whysacrifice some cpu cycles for something that wont be used on my car ) But as part of the reinstallation, I deleted my RR folder, redownloaded the RR binary, unzipped to c:\rr and installed your skin there. Heres's a copy of my RR.INI if u want to take a look at it
    My current project
    Jetta 2000 MKIV
    SP13000/Xenarc 7"
    100GB / 512 RAM / GPS / Wi-Fi
  3. #43
    Jan 2006
    I seem to have a weird flash issue with the menu.skin screen. Originally when first loading, there was a white box right above where the play, forward, previous buttons were so I looked into menu.skin to see what it may be.
    It seems to be looking for LS.swf. Anyone else having this issue? There's a copy of LS.swf under ALT\. Once copied, it doesn't exactly fit the skin. (attached screenshot)
    Also, am I the only person having problems non-english fonts? It worked fine with the old LSX's but no matter what I do, I cannot get RR to format the id3 tags within the playlist and audio browser. What youa see in the screenshot is actually the file name. It seems that RR always append 'yt' before as shown in screenshot 2.
  4. #44
    Low Bitrate TxAxZxZ's Avatar
    Dec 2005
    Ft. Walton Beach, FL
    Great Skin LS!!
    I am also having the italicized problem. My entire system changed to italicized fonts including LSVOID 2.0. At first I thought it was something localized with my system until I checked out the forum here and found two others having the same problem. I did a restore to a point prior to installing LSVOID 2 and corrected the problem. I reinstalled VOID and the italicized problem is back.
    Also, is the GoogleEarth button working or is that for future use? And what is the VOID button used for?
    Thanks again for all your hard work and I hope you celebrate with a alcohol induced happy new year. (I plan to ;op)
    Griz
    Jeeputer Project
    - Design <<< 100% >>>
    - Construction <<< 99.5% >>>
  5. #45
    Constant Bitrate Gixxer's Avatar
    Jun 2005
    Daphne, Alabama
    ^^^ Same here with the italics
  6. #46
    Constant Bitrate venealis's Avatar
    Apr 2006
    Richmond, VA
    old vs new
    Ls love the new skin. but i was wondering if it is at all possible to make the playlist where you rate the music and make playlist a option on the older style of Void. What i mean is i like the way the older version was laid out with the audio but i like the options with the new. Reason being i have a 4x7 screen and its a little tight trying to manipulate the screens while moving. I would just stick with the old but i love the other veatures that you have in v2.0
  7. #47
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by jewps View Post
    what version of flash are you using? To turn the flash compass on/off
    click OPT> go to screen 5/5
    your screen should look like this,
    beer replenishment fund
    mp3car live search
  8. #48
    Aug 2003
    Chicago
    also for all those with ITALIC fonts I'll be looking into this ASAP, im certain this is a font issue. If all the fonts on your entire computer are italic, im sorry for that. For those with the italic issue please state what version of windows you are running and if it is US ENGLISH version of windows.
    I tested the installed fonts on 4 machines and some external testing and this never happened. My machines all run WinXPpro (US ENG) or WinXP MCE2k5 (US ENG).
    To try and narrow down the font that is causing issues.
    This is a list of fonts that are installed.
    ARIALN.TTF (arial narrow)
    ARIALNB.TTF (arial narrow bold)
    ARIALNBI.TTF (arial narrow bold italic)
    ARIALNI.TTF (arial narrow italic)
    ARIRDBD.TTF (arial rounded bold)
    LSXVOID.TTF (custom font with icons/symbols)
    webdings.ttf (symbols)
    wingding.ttf (symbols)
    WINGDNG2.TTF (wingdings 2 symbols)
    WINDGNG3.TTF (wingdings 3 symbols)
    Each font is only installed if it is not already on your machine.
    Try to remove each font one by one to see which font is causing the issue.
    mp3car live search
  9. #49
    Dec 2006
    i had this problem also, it seems to be the LSXVOID.TTF that is causing it... it seems to mess with the default arial font for some reason... deleting it fixes the italicized problem
    now the only problem i'm having is getting winamp's avs plugin to embed... other than that great skin, definitely my favorite at this point
  10. #50
    Low Bitrate Cycfari's Avatar
    Nov 2006
    N1 22.921 E103 54.207
    Great Skin! I'm newbie & your skin really inspired me to start my carputer project this year. I spent my whole nite yesterday toying with this skin. Maybe my wife will divorce me once the project start.
    Is it possible to use FreeFone & nRoute(Garmin GPS) for this skin?
    Cheers!
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
