Page 50 of 317 FirstFirst ... 404142434445464748495051525354555657585960100150 ... LastLast
Results 491 to 500 of 3166
Thread: Lsx Void 3.0
  1. #491
    Constant Bitrate venealis's Avatar
    Apr 2006
    Richmond, VA
    iGuidance
    I know the question has been asked a thousand times. But LS are you still looking to include a new reshaked version for iGuidance with 2.5? The suspense is killing me for the next release. Keep up the excellent work.
  2. #492
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by venealis View Post
    actually forgot about it to be honest. But thanks for the reminder, it is something i still want to do, the current version sucks IMO.
    beer replenishment fund
    mp3car live search
  3. #493
    May 2004
    Just some questions.. One, about the igautoswitch function. When I have it enabled and I hit the volume slider it always takes me to the navi screen. When I disable igautoswitch its fine. Ever experience this?
    Two, is this skin case sensitive? Reason is I have an old windows folder sync program that converts files to lowercase and I've never had a problem until recently with the night skin. The clock.swf logo or album art images don't appear, but they do with the day skin. But the same set of files, just normal case work fine on my computer.
    Three, how do I get the day-night skin to automatically switch? I saw the general.ini file with the times set there but how do I enable it?
    Apr 2006
    Richmond, VA
    sucks maybe not but i can tell it's not up to a LS standard LOL.
  5. #495
    May 2004
    Also, ATT does nothing for me with Audio or XM. It says ON next to it but the volume is still the same.
  6. #496
    Aug 2003
    Chicago
    Quote Originally Posted by tmar89 View Post
    it should only work with winamp, what version of winamp are you running (really shouldnt matter though)
    mp3car live search
  7. #497
    Nov 2005
    Maryland
    ATT Button
    This is something I've noticed as well. On the main screen it does seem to lower the volume but just by a very minor amount. I believe I read earlier in the thread that you could adjust how much it reduces the sound. What I find odd is that the ATT button on the GPS screen does dramatically reduce the sound volume. So the two buttons must be linked to different commands.
    Anyway, I suggest you search back through the thread to find that previous post and adjust the settings accordingly.
  8. #498
    May 2004
    2.95. Yeah, it seems there is a variable to adjust in the skin.
    I'm confused with the ATT script. How does the volume get lowered for ATT ON? I don't see an associated command with "ON".
    Code:
    /ATT CODE START/========================================================
    "OFF","!PRESET;ATT||SETVOL;Master;10"
    "ON","PRESET;ATT"
    "SETUPATT","SETVAR;attvol_low;120||SETVAR;attvol_high;255||SAVETOINI;attvol_low;$attvol_low$||SAVETOINI;attvol_high;$attvol_high$||SETVAR;ATTENTION;$ATTENTION$||SAVETOINI;ATTENTION;$ATTENTION$"
    "SETVAR;ATTENTION;$ATTENTION$||SAVETOINI;ATTENTION;$ATTENTION$"
    "ATTON","!PRESET;IG3;WINAMP||SETVOL;WINAMP;$attvol_low$||SETVAR;ATTENTION;1||SAVETOINI;ATTENTION;$ATTENTION$"
    "ATTOFF","PRESET;IG3;WINAMP||SETVOL;WINAMP;$attvol_high$||SETVAR;ATTENTION;0||SAVETOINI;ATTENTION;$ATTENTION$"
    /thE command "DUCK" is used for all att buttons
    "DUCK","BYVAR;ATTENTION;ATTON<<ATTOFF"
    /ATT CODE END/========================================================
    And Rabid_Child is right. When I hit ATT I looked at what Winamp was doing and it goes between 100% and 47%. And the volume bar in the skin isn't affected. But in the NAVI screen, the ATT affects the skin's volume bar, taking it down to 10% always. So it seems the ATT functionality is different depending on if you are on the main screen or NAVI screen.
  9. #499
    May 2004
    Also, in page 4 of the options, Ding Sound doesn't change from OFF. What is it supposed to do?
  10. #500
    Aug 2003
    Chicago
    not sure if RR is case sensitive or not, but it sounds like it may be. All the .swf files by default are all lowercase. Have you tried changing the case and it works after that? THe only difference between the day and night is the image files. There may be some issues with using a sync program to sync the skin. A few of the options in the skin are Dependant on files being present or not to determine if a feature is on or off, so for example if you have an option turned on, do a sync and by default if the feature is off, the skin will think its off (but its really on and works as if its on) but you go to turn it off and now the skin thinks its off but its really still on. Puts you in a situation where you have to manually move a file and there isnt any docs on what file needs to be moved etc. There are about a dozzen features that work like this.
    There are some checks in place to make sure this doesn't happen so a restart of RR should auto correct it but its still possible you may have a problem in this situation.
    If changing the case works for you then you've found the issue, if not i would recommend reinstalling the skin from scratch and make sure you clear out lsxvoid settings in rr.ini before hand.
    There are some threads on how to do the autoswitch, there are a few methods on how to do it, but honestly i cant give a step by step as i personally myself have never autoswitched and still use the night version fulltime. THe dayversion was a labor of pain and honestly i hate the way it looks. There maybe a rework of the dayversion one day, but its very unlikely as its a pain in the ***.
    oh about the autoswitch.
    the way autoswitch works is if anything changes your wav volume it will assume that IG is the app that changed it and take this as IG is talking (this is how it works) so you have to set your wav volume and make sure NO other app changes it, ever. So in RRConfig set RR to map the volume control to MASTER instead of wav and it will fix that.
    mp3car live search
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
