Page 51 of 317 FirstFirst ... 414243444546474849505152535455565758596061101151 ... LastLast
Results 501 to 510 of 3166
Thread: Lsx Void 3.0
  1. #501
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by tmar89 View Post
    Also, in page 4 of the options, Ding Sound doesn't change from OFF. What is it supposed to do?
    somehow i think this got broken inbetween the last two releases, it is now fixed in my local version and will be working in the next update.
    Somehow i think the skineditor screwed up a file cuz the command is totally broken in the .skin file. Ill check over it again before i release to make sure it still works.
    beer replenishment fund
    mp3car live search
  2. #502
    Aug 2003
    Chicago
    2.95. Yeah, it seems there is a variable to adjust in the skin.
    I'm confused with the ATT script. How does the volume get lowered for ATT ON? I don't see an associated command with "ON".
    Code:
    /ATT CODE START/========================================================
    "OFF","!PRESET;ATT||SETVOL;Master;10"
    "ON","PRESET;ATT"
    "SETUPATT","SETVAR;attvol_low;120||SETVAR;attvol_high;255||SAVETOINI;attvol_low;$attvol_low$||SAVETOINI;attvol_high;$attvol_high$||SETVAR;ATTENTION;$ATTENTION$||SAVETOINI;ATTENTION;$ATTENTION$"
    "SETVAR;ATTENTION;$ATTENTION$||SAVETOINI;ATTENTION;$ATTENTION$"
    "ATTON","!PRESET;IG3;WINAMP||SETVOL;WINAMP;$attvol_low$||SETVAR;ATTENTION;1||SAVETOINI;ATTENTION;$ATTENTION$"
    "ATTOFF","PRESET;IG3;WINAMP||SETVOL;WINAMP;$attvol_high$||SETVAR;ATTENTION;0||SAVETOINI;ATTENTION;$ATTENTION$"
    /thE command "DUCK" is used for all att buttons
    "DUCK","BYVAR;ATTENTION;ATTON<<ATTOFF"
    /ATT CODE END/========================================================
    And Rabid_Child is right. When I hit ATT I looked at what Winamp was doing and it goes between 100% and 47%. And the volume bar in the skin isn't affected. But in the NAVI screen, the ATT affects the skin's volume bar, taking it down to 10% always. So it seems the ATT functionality is different depending on if you are on the main screen or NAVI screen.
    You are right, there are 2 att functions. On is for general use and the other is specificly for navi. I cant remember right now why i did 2 of them, but there is a good reason for it, trust me
    In the update there are settings in the options screen to set the volume levels for the att functions.
    Looking at the .skin file for the navi, the att button has code in it similar to above, when i think it should probably be using the code from the ExecTBL.ini file. Ill have to take a look at it and make sure its setup the way i wanted it to be.
    The global command for att is "DUCK", the ON and OFF commands above i think dont do anything or aren't used by anything anymore (not sure right now)
    But... the way it works is by a variable, so if you set it to ON and restart RR it will still be set to ON. In rr.ini there is a var called ATTENTION that has a value of 0/1 for the status of att on/off. When you click the button to turn it on, it saves your current winamp volume to a preset then changes the winamp volume to the value set from a var in rr.ini (attvol_low) and sets the attention var to on. The red text in the skin that says ON is based on the attention var. Its kind of complicated how it works, since there isnt a att feature in RR by default you have to code it yourself.
    There has been some minor changes to this feature in the update, ill revisit the ATT button in the NAVI screen to make sure its doing what it should do.
    mp3car live search
  3. #503
    May 2004
    Thanks for the detailed responses. They are always appreciated.
  4. #504
    Low Bitrate taylorgauss's Avatar
    Feb 2007
    Seattle
    This is a great thread thanks everyone. I am currently purchasing my components and system and plan to run this Skin. I am wondering if i will need any addational software to get the navigation to work?
  5. #505
    Aug 2003
    Chicago
    Quote Originally Posted by taylorgauss View Post
    Take your pick,
    its setup by default to work with iNav's iGuidance 2 & 3, Freedrive and MapMonkey.
    If you live in NorthAmerica you likely want to use iGuidance.
    These apps are all separate but integrated with iGuidance having the tighter integration in this skin.
    mp3car live search
  6. #506
    Feb 2007
    How do I set it up so that the song being played gets updated on the main page? If I go FFD through the songs, the list in the middle updates and shows which one is playing, but if a song finished and it goes to a new song, it does not update. I have the same problem in the AUDIO section. I tried to search this thread, but was unsuccessful. Thanks.
  7. #507
    Aug 2003
    Chicago
    Quote Originally Posted by nothix View Post
    Open RRConfig.exe , there is a setting under Music that deals with this feature.
    check "Highlight Current playlist song on change"
    mp3car live search
  8. #508
    Aug 2003
    Chicago
    Here is a screenshot of the IG3 mod update.
    Note this will only be for IG 3.01
    Im moving away from the dark background for a few reasons, one being so it works better in daytime as well as night and also so the black text on some dialogs shows up better on the lighter background.
    This will be included in the 2.5 update in the usual location.
    mp3car live search
  9. #509
    Sep 2005
    Wow, looks great! Is there any way you can implemment a version that does not use the autoit button for loading IG stuff? I prefer having the menu button.... just something not quite as tacky as the bright blue menu thing. I think I could figure out how to mod the menu button if you left it in there...
  10. #510
    Aug 2003
    Chicago
    Ill probably have a switch to turn the ig flyout menu on/off. I have to rewrite it to work with IG3.1 anyway.
    Im still going to remove the blue button though, and not replace it with another graphic. In IG3.1 even after you remove the graphic the text "menu" still is visible so that should be cool to know where to click
    mp3car live search
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
