looking great. question though, are you going to be skinning FreeFone from CDR into 2.5? I know that you can just embedd it and it will work along with the front end, but for reasons of looks is why the concern. Thanks.
Printable View
that was the intentions i had when i read that 1.4 would allow full integration with RR, but you still cant change the way it looks, its still flash. So there really isnt any difference between the standalone version and the RR version, they both use flash, one is just a .exe.
This is becoming kind of cliche, but great skin and you're a saint for the support of your skin.
The only issue i've found is how do we download files with the included web browser?
that is a problem. Im not sure what the issue really is, has something to do with the webbrowser plugin. It keeps stealing focus and forcing itself ontop every 3 sec. If you run it standalone it wont do it, but the way it works is if you have RR open and the standalone open it screws up some stuff.
WEB support just seems to not be there all the way yet as i think u have this same problem with the RR built in web support. If we could merge the webplugin with the built in web support we would be better off i think.
There are a lot of little things that just dont work right that i usually just open FF standalone to download a file or something similar.
If someone knows of a way to remove the file menu in FireFox i would switch to that
Yeah, that's what I did. I shouldn't really be downloading any files after I get everything situated... if that ever happens
I posted this in a closed LSX released thread...so this is a repost.
I have read through this thread and I have tried to Google this problem. There are some people with this problem with other skins, but I don't understand how they are fixing the problem.
I have a fresh install of LSXVoid 2.02 and a fresh install of RoadRunner (I am not sure of the version, but when I try and update it says there is no versions). Every time I open the program with LSXVoid 2.02 (Day or Night) I get an Error 13 Type Mismatch.
How do I fix this? Any help would be greatly appreciated.
what version (exact version date) of RR are you running and have you edited the .skin files in any way?
My version of Road Runner is 1-16-06. Which is kind of old so I will try and find updates. Also, I haven't changed any .skin files. The other skins works, but this one...which stinks.
thats likely your problem, your version is very old, over a year old.
The current beta version of RR is 1-22-07
beta RR releases are found HERE
