Page 53 of 317 FirstFirst ... 3434445464748495051525354555657585960616263103153 ... LastLast
Results 521 to 530 of 3166
Thread: Lsx Void 3.0
  1. #521
    Sep 2006
    Richmond, Tx: USA
    I have read through out all the posts yet but do you by any chance have a FAQ section about how to setup visuals, calender, pictures ?
  2. #522
    Registered User vfinterceptor's Avatar
    Oct 2005
    up-the-hill-turn-left-by-the-big-tree
    Hi LS,
    Quick Q:
    What dvd program works best with your skin. Windvd? If so, is there a specific version?
    I'm using windvd platinum 6, but it's giving me all kinds of problems with locking up when running with lsx and it won't embed.
    Or am I missing something obvious?
    Hmm..... maybe I better check the program name again.......
    Cheers
    BJ
    *edit* Frig, found the problem right after I posted, name was wrong. But now that I have it embedding, I find the pop under control buttons only do the audio and have no effect on video playback. Is this the way it's supposed to work? And once the button bar is up, I can't get it to supress.
  3. #523
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by vfinterceptor View Post
    Hi LS,
    Quick Q:
    Cheers
    BJ
    it works best using the default dvd support in RR. I know, prob not what u wanted to hear. You may find that windvd and or powerdvd will embed with the skin, but this is mostly failed experiments. None of the standalone dvd apps integrate tightly.
    MPC works good with dvds also, so if you dont want the intergrated dvd in RR, use MPC instead, this is what i use.
    Quote Originally Posted by ajamils View Post
    im sure u havnt read all the post, there are a few just on visuals.
    Visuals are winamap visuals, thus some prerequisites of using winamp are required. If you downloaded the visual presets from this thread, they go into the AVS folder in your winamp install. In RRConfig.exe choose AVS as your visual and also in winamp choose AVS (advanced visualization Studio) as your visual plugin. Make sure you also set winamp to use classic skins, and not modern else the visuals will not embed correctly in RR. Also, you want to make sure you have the right version of winamp. Various versions cause different issues with embeding etc. I recommend winamp 5.13, esp if you plan to use the visual preset for this skin.
    The calendar is rainlendar, you have to download it, there are links to this in the first couple post (i believe). If not there i know there is a link in the archive history thread for this skin.
    To enable pictures open RR.ini and add or edit this line
    picspath=V:\Users\liquidsmoke\Pictures
    change the path to your pictures.
    beer replenishment fund
    mp3car live search
  4. #524
    Constant Bitrate ephyouckay's Avatar
    Oct 2006
    wow... ive been missing out. i just took a peak at the video and its amazing. i cant believe what you did with this skin. cant wait to try it out. thanks!!!
    i appreciate the time and support youve dedicated into this skin. Thanks!
  5. #525
    Sep 2006
    Richmond, Tx: USA
    Quote Originally Posted by liquid_smoke View Post
    THanks for the reply. I have already downloaded and installed the software for the calender but when I press the calender button...nothing happens. Do I need to do any configuration in the skin or RR ?
  6. #526
    Oct 2005
    Hmmm.... when I use the internal player it plays in 4:3 even though I have 16:9 in RR.ini
    Interesting......
    Cheers
    BJ
  7. #527
    Aug 2003
    Chicago
    If you downloaded rainlendar 2 you will have to edit a line in ExecTBL.ini (inside the skins folder, for both day and night versions)
    Find this line
    "CALENDAR","RUN;C:\Program Files\Rainlendar\Rainlendar.exe"
    change the path to point to the install for Rainlendar 2. Its backwards compatible so the skin should still work in the newer version. Ill prob make an update for it to use the newer format at some point.
    Interesting......
    Cheers
    BJ
    There should be a zoom button in the skin to change the aspect ratio.
    mp3car live search
  8. #528
    Oct 2005
    Duh, found it. Talk about feeling stupid.
    I didn't know it was the "X" button. I assumed it was stop, delete, exit or something similar.
    Cheers
    BJ
  9. #529
    Aug 2003
    Chicago
    Cheers
    BJ
    yeah, that may be a tad misleading now that you mention it, ill see if i can come up with a better icon. Thats the main reason i use Text instead of icons for 99% of the skin, so everything is clear. Maybe an icon that was 2 boxes, one wide and one square?
    mp3car live search
  10. #530
    Aug 2003
    Chicago
    2.5 update preview
    mp3car live search
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
