Page 58 of 317 FirstFirst ... 8484950515253545556575859606162636465666768108158 ... LastLast
Results 571 to 580 of 3166
Thread: Lsx Void 3.0
  1. #571
    Dec 2006
    Iowa
    Those both work to close cdrip, but I cant see the roadrunner. Its still running but theres no window. I noticed some of the other apps use a kill.exe. Would this help? Thanks for your help.
  2. #572
  3. #573
    May 2005
    Columbia, South Carolina
    Why am I getting this error?
  4. #574
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    where have you installed Road Runner, is it on drive C: and in the directory Program Files\Road Runner.
    *edit actually it looks like I can answer that. You seem to have installed Road Runner to C:\Road runner, unfortuanately it looks like LS has hardcoded the paths for that function to C:\Program Files\Road Runner.
  5. #575
    May 2005
    So can I just move the road runner dir from c:\Road Runner to c:\program files\road runner.
    Would everything still work provided I update any shortcuts?
  6. #576
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    weird that your even seeing that. igaddon never worked for me, i cant even find any references to it in my files, but it is possible its enabled in the downloadable version of the skin.
    You should be able to install the skin anywhere u want, mine is installed under V:\Road Runner\skins\LSX_VOID_NIGHT
    But there is one case where the ratings plugin does have hard coded paths, this was fixed in an update to the plugin, but then people started having problems even getting it to work anymore. Im not sure what the status of the ratings plugin is, but if you have problems getting it to work try to update it. As for the igaddon, open ExecTBL.ini found in the skins folder.
    Fine the line that references that file, then post that line here. Dont remove the entire line as i think there are multiple commands on that line that do other things.
    beer replenishment fund
    mp3car live search
  7. #577
    May 2005
    "IGPAUSE","!PRESET;IG3;WINAMP||SETVOL;WINAMP;5 0||\iGarrows\GAddOn.exe"
    "IGRESUME","PRESET;IG3;WINAMP"
    Ok, so I removed "\iGarrows\GAddOn.exe" from the file ExecTBL.ini. That fixed the problem. Thank you.
    My other two issuses are:
    Winamp doesn't pause when IG is giving directions. Is it suppose to?
    I can't seem to get the skins to switch automatically. I even tired setting the times to military time in the general.ini file.
    any thoughts?
    btw-your skin is pwns
  8. #578
    May 2005
    A few questions:
    Is it possible to change the "Ext App" top buttons? I can change the main screen buttons. When I hold the buttons on top of the "Ext App" screen nothing happens.
    Is it possible to remove the left and right arrow in the main screen? I want my options to be fairly limited since I dont have enough features to make all the buttons from the other screens work.
    How do you change the GPS on top to switch from km/h to mi/h. When I have my GPS Connected and run iGuidance that shows my MPH correctly but the skin doesnt seem to change.
    Amazing skin liquid_smoke. I love yours cause its the most easily customized and the graphically its beautiful.
  9. #579
    Aug 2003
    Chicago
    by default the skin will not pause winamp when IG speaks, but yet it will lower winamps volume to a good level so you can clearly hear the ig voice prompts, but the music still plays in the background. For me, this is a better option than stopping the music, but thats just my personal opinion.
    a lot of work has been done to the skin since the last available version, and right now its on the tipping scale from being a point release to a full major release as a lot of things have been added, some removed, a lot of fixes and some reorganization of the setup (opt) screens. So if i cant remember exactly were something is at in the released ver thats why.
    if you do not want it to lower the winamp vol, just edit the original line of code from above to be like this.
    "IGPAUSE","PAUSE"
    "IGRESUEM","RESUME"
    as for the skin to auto switch, the jury is still out on this feature. Personally ive never seen it actually work the right way. There are options for it in a few places, also a few different methods people do to switch them. I normally just use the night version of the skin all the time, the day version really was only created specifically for those who kept asking for it. So squeaky wheels do get the oil. So i really cant offer too much advice on the feature or how to get it to work the best. Others here can chime in on what they are doing to get the autoswitch to work and what method (gps based, etc) they are using.
    mp3car live search
  10. #580
    May 2005
    Quote Originally Posted by liquid_smoke View Post
    "IGPAUSE","PAUSE"
    "IGRESUEM","RESUME"
    Wow, thanks for the quick response. I agree with you on the fact that lowering winamps volume is better; however, I can't even get that to work.
    I've read through a few threads about it and every setting seems to be correct. But it doesn't work. I realize I'm being vague with my discription, as it could be one of a number of things, but what would be your best guess?
    Is the option in the main screen that is labeled "Autoswitch On" for the day/night switch or is that for the IG directions switch. (which, btw, is awesome) (when it switches to the gps screen, I get 2 white flashes that encompass the entire screen, then it goes smoothly to the gps screen. Is this caused by my slow 1 ghz c3 processor?)
    once again,
    thanks
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
