Page 67 of 317 FirstFirst ... 17575859606162636465666768697071727374757677117167 ... LastLast
Results 661 to 670 of 3166
Thread: Lsx Void 3.0
  1. #661
    Aug 2006
    Pakistan
    Quote Originally Posted by liquid_smoke View Post
    you have to setup your own keymaps for RR. To save a playlist that is unique from the 1-5 all you do is click and hold the 2 buttons that cycle through the 1-5 and you get an option to save the list as a custom name (thats not included in the 1-5). Also, when you click the PList button there is a SAVE button on the next screen that will also save what ever is loaded as a new playlist.
    liquid_smoke, thanks for the reply. When I click and hold buttons which cycle through 1-5, a popup opens which shows the slots 1-5. Here I have option to save with auto or my own playlist name. But in both cases it saves to one of 1-5 slots. The same is with "Save" button inside PList. It also pops up the same dialog box to save the playlist in 1-5 presets.
  2. #662
    Feb 2007
    Quote Originally Posted by vfinterceptor View Post
    For the luva pete!
    Search the thread man! This comes up over and over!
    Here:http://www.mp3car.com/vbulletin/1043019-post621.html
    here:http://www.mp3car.com/vbulletin/1039813-post610.html
    here:http://www.mp3car.com/vbulletin/1035650-post563.html
    here:http://www.mp3car.com/vbulletin/987848-post101.html
    And it goes on and on.....
    Update your flash.
    Maybe the first post should incorporate and index to common questions or something!
    LS is a saint and just keeps answering over and over, but come on people! At least search the thread an TRY to help yourselves first!
    Cheers
    BJ
    Right, sorry to drag this out but Ive got the latest flash and it hasnt helped. Is there something else I have to do?
  3. #663
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by aghazi View Post
    you are correct. For some reason i thought it worked the otherway, till i tried it out and remembered why i did it the way its done now. The custom name in the 1-5 is for display only.
    Ill have to change the SAVE button on the plist screen in the update and make it just a generic playlist save instead of the 1-5.
    In the mean time, i believe this will work.
    STEP 1. load some music
    STEP 2. save it to one of the 1-5 slots
    STEP 3. go to the plist screen, select the Preset1-5 list item and click RENAME
    this will let you rename the actual m3u playlist file used by the 1-5 slots.
    The one you rename will be missing as soon as u rename it, so if you plan to cycle to it you will have to resave that slot. The skin will auto recreate the m3u file as it needs to.
    ill narrow this down to a one click operation in the update.
    beer replenishment fund
    mp3car live search
  4. #664
    Aug 2003
    Chicago
    Quote Originally Posted by J7MAN View Post
    a search for "flash white box" in the rr forum should lead you to several results to fix this.
    This is the first faq in the RR faq section.
    when you update flash, make sure you are using IE (internet explorer) and not FireFox else you will just be updating the flash player plugin for firefox and not the player that the OS uses.
    mp3car live search
  5. #665
    Aug 2006
    Pakistan
    GREAT! Thanks!
    I tried to change the List2 skin and remap the SAVE button. I found that it is a label not a button and I don't know how to use label. So I created a button, set the command to SAVELIST and placed it on top of existing label. It works for now but on UI side, it shows a white box instead of red when highlighted.
    I will be waiting for this update. Thanks again.
  6. #666
    Constant Bitrate rigg419's Avatar
    Apr 2006
    Behind the Orange Curtain
    between this version and the upcoming one, this skin is so popular and so many questions are getting asked over and over that it needs its very own wiki or a faq page or something
  7. #667
    Registered User vfinterceptor's Avatar
    Oct 2005
    up-the-hill-turn-left-by-the-big-tree
    Quote Originally Posted by rigg419 View Post
    Good idea!
    Heck, give it it's own topic forum with an FAQ, bugs, suggestions, etc at the top!
    Cheers
    BJ
  8. #668
    Aug 2006
    Pakistan
    Load playlist hotkey
    I want to assign a hotkey (will use in girder) to the "LOAD" button on PList screen. This load button loads the currently selected playlist and takes back to the audio screen. I successfully created the command as follows
    "LOADLIST;$PLAYLISTPATH$my.m3u;
    This load the my.m3u in path defines in config file.
    But as you can see, I have hardcoded the name of playlist. I want to get the name of the playlist which is currently selected and place it in above command. Kindly let me know how to do this.
    Thanks...
  9. #669
    Newbie Headshot12's Avatar
    Oct 2006
    DFW Texas
    Hey, I just installed LSX, and I'm already addicted to it. However, I've got the white box of no flash, and rrdownloads.net has apparently lost its lease. Can anyone point me to a "flash.zip" download link? (and I did search, I swear!)
    What manner of man are you that can summon up fire without flint or tinder?
  10. #670
    Aug 2006
    Pakistan
    Quote Originally Posted by Headshot12 View Post
    http://www.filehippo.com/download_flashplayer_ie/
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
