Page 74 of 317 FirstFirst ... 24646566676869707172737475767778798081828384124174 ... LastLast
Results 731 to 740 of 3166
Thread: Lsx Void 3.0
  1. #731
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by rx2nr View Post
    where do i set the photo path directory? ive seen the audio and video, checked the rr.ini. checked the skins, the readme, clicked on buttons, settings .. and still couldnt find it .. ive searched and found one person having a similar problem and has gone unanswered. other lsx threads dont have it either .. am i missing something?
    open rr.ini and add this line
    picspath=V:\Users\liquidsmoke\Pictures
    change to your path
    beer replenishment fund
    mp3car live search
  2. #732
    Jul 2006
    Chicago
    wooho! thanks... im lovin it
    props .. uve set the bar high .. no other skin comes close to the level of this skin.
  3. #733
    Aug 2003
    Chicago
    im not done yet
    thanks
    mp3car live search
  4. #734
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    I just installed the latest version of RR...and now LSXVoid crashes every time it starts...sometimes after it runs it won't crash again.
    The standard skin does not crash.
    Nothing stands out in the debug logs.
    Where do I start looking?
  5. #735
    Aug 2003
    Chicago
    Quote Originally Posted by DodgeCummins View Post
    send me your debug log when it crashes and also your rr.ini.
    send them liquidsmoke+bugs@gmail.com
    Not really sure where to start as there have been a lot of changes to RR since the last release of this skin. There has also been a massive amount of changes to the version i have locally.
    To be honest if you are using the last available version of this skin, there really is no need to update your RR version yet, until i release the next update as none of the new features in RR will be available to you till the skin takes advantage of them.
    So if you are having problems i would just go back to the last ver of RR.
    mp3car live search
  6. #736
    Maximum Bitrate SjLucky's Avatar
    Jul 2003
    Meridian, Mississippi
    If I may request a feature update, I ran across the weather videos and I was wanting to see if there was anything for around my area and there wasnt anything really, so I checked out accuweather and there was a long list of cities and a few pretty close to me, close enough to work. Anyway to use their videos?
    Quote Originally Posted by menudude View Post
    thank you all for your help minus the useless post by sjlucky...
  7. #737
    Oct 2000
    DFW area
    LS, yea I was getting ready to put the old version back on (once I found a copy).
    But it seems (so far it hasn't crashed) that RR added (or changed) how it handles the artist/title ID3 display. It has three options and it defaults to rolling...that caused crashes...the rolling and scrolling causes crashes...but so far the scroll itself does not cause a crash.
    I assume that is it...I don't have a working copy of the older version of RR to check, but it is a selection at the bottom of the music section of RR config.
  8. #738
    Aug 2003
    Chicago
    scrolling text has been in RR for as far as i can remember.
    No text in the skin should scroll though, as it kills your cpu so i dont use it, not sure why u would see anything scrolling even with it set in rr.ini but i may be wrong. Not sure what the default option for this in rr config is but it could just be incompatible with your machine and u never knew it till u did a new install.
    Did you use the installer to install RR or did you manually install? I know the installer sets some options that probably shouldn't be set to the values they are, that may be an issue also.
    so everything is cool now ?
    mp3car live search
  9. #739
    Aug 2003
    Chicago
    Quote Originally Posted by SjLucky View Post
    i believe the videos actually are from accuweather, even the google ones. If you check the google weather site, its prob updated with more cities since i added that feature, you can prob find a city close to you.
    LSXCOLORS.txt is the file that you need to edit to change the url of the forcast video, but they must come from google (else you'll have to edit the .skin file and some other stuff to change that).
    Go HERE to see a list of all the forcast videos.
    The url for the videos looks like this below.
    hxxp://video.google.com/googleplayer.swf?docId=-1513940121655637936&hl=en
    you only need the part in bold. When you look at the LSXCOLORS.txt file (bottom of file) you will see how it works, just edit the line that starts with
    /DEFINE GOOGLEVIDEOWEATHER
    to link to the video you want to use.
    mp3car live search
  10. #740
    Oct 2000
    DFW area
    Nevermind...it wasn't the text scrolling (like you said)
    I had to wipe out that RR install, and reinstall the older one.
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
