Page 78 of 317 FirstFirst ... 28686970717273747576777879808182838485868788128178 ... LastLast
Results 771 to 780 of 3166
Thread: Lsx Void 3.0
  1. #771
    Mar 2005
    Ok, maybe I'm just an idiot....considering search isnt helping I'm leaning towards user error. Where can I change the paths of the maps that the weather option is pulling from?
    Also, I keep getting a red bar that likes telling me "Goodnight " It just randomly pops up as I'm moving around in the skin...any ideas? lol
    Love the skin
  2. #772
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by Daven View Post
    Love the skin
    im guessing your talking about the weather images, there is a script that downloads the images. You will need to install autoit to edit the script and recompile it to a .exe to make changes to them.
    the file name is WEATHER_LSXVOID.au3 and its found inside the skins folder.
    The contents of the script are the code below.
    Code:
    FileChangeDir(@ScriptDir)
    InetGet("http://image.weather.com/images/maps/current/curwx_600x405.jpg", "USCWeather.jpg", 1)
    InetGet("http://image.weather.com/web/radar/us_radar_plus_usen.jpg", "USDoppler.jpg", 1)
    InetGet("http://image.weather.com/images/maps/current/acttemp_600x405.jpg", "USCTemp.jpg", 1)
    you can point the url to any link you wish that has an image. Do not edit the text that is marked red above.
    after you make the changes (and ofcourse have autoit installed) right click the .au3 script file and compile. Done.
    As for the GOODBYE, you should never ever see that, its disabled by default, and even when its enabled you should only see it when you exit RR. So im not sure why you see it unless you edited the ExecTBL.ini file for the skin and mistakenly enabled it. Send me your ExecTBL.ini file and ill send it back to you with it disabled.
    beer replenishment fund
    mp3car live search
  3. #773
    Aug 2003
    Chicago
    Quote Originally Posted by LLR View Post
    Thanks for a quick response, Enforcer
    What should or shouldn't? I do to close those scripts automatically? Kill them manually is the only option for now
    Moreovere, it's not only me - some ppl have the same problem too
    Im betting that its the ratings plugin that is bundled with the skin. The latest version of the ratings plugin fixes the hard coded paths. The script is looking for your RR install to be in C:\Program Files\Road Runner , if you change your install to that path it will fix the multiple instances of the script from running OR you can also update the ratings plugin to the latest version. Its found in the RR plugins subforum.
    Note: I cant promise the latest version will work with the 2.x version of the skin but it should be ok.
    mp3car live search
  4. #774
    Mar 2005
    Quote Originally Posted by liquid_smoke View Post
    stuff
    Yup, Thanks for the info, got the maps adjusted to show Texas. I PM'd you a link to my ini file, thanks for offering to take a look.
  5. #775
    LLR
    LLR is offline
    Dec 2005
    All that talk about scripts is Greek to me.
    Ok. I install RR to C:\Program Files\Road Runner
    I dont want to install (or change) anything else - I JUST WANT TO DISABLE THE F***ING SCRIPT
    So, please bear with me for a sec.
    A right-mouse click (if I'm not mistaken) says it's IGCONTROL.exe
    1) How can I "find" what script it is? (WTF is "script", btw?)
    2) How can I "disable" it?
    TIA
  6. #776
  7. #777
    LLR
    LLR is offline
    Dec 2005
    Thanks for the help, Enforcer. I found the answer using search
    EDITED
    Just tried it and it works like a charm.
    Oh! BTW I "disabled" all of 'em
  8. #778
    May 2005
    Can someone please post a link the site does not go past the main page...
    thanks.
  9. #779
    Low Bitrate DoubleC's Avatar
    Nov 2005
    ATX
    Post 744 in this thread page #50
  10. #780
    Newbie blauhung's Avatar
    Feb 2007
    Hi LS, i love your skin so far, but i'm playing around with things trying to make a nice skin to integrate with the Google earth plugin and I would like to have it make use of a drop down menu.
    [disclaimer] I'm new to skinning [/disclaimer]
    anywho, first off do you mind if i bastardize some of code for my own uses? once this one's out of the way.
    I'm planing on using your POPUP.skin as a template for what i want to do. this popup will have a few buttons that go through some of the basic functions of the GE plugin. I don't plan on using the "over-my-head" configurable buttons that you have going in there, all directly coded functions. My first kinda road block is figuring out how to get the popup window to popup on top of the existing GE window (i used a tweaked copy of your RRearthx.skin for this and it looks very pretty). so far I can get it to popup but the RRearthx.skin closes so i'm left with my desktop in the open spaces. my first thought is to create a skin that copies the base RRearthx.skin exactly (w/o buttons) and just put the popup frame on top of it in the image files, but then i'm guessing the application frame will appear on top of that. If that doesn't work, i'm thinking that there must be some way to just overlay one skin window on top of another and ignore all the clicks on the lower screen, but then i'm unsure how execute requests are handled from one skin to the lower (but i think this one is probably a non-issue).
    any brain storming on how to do this anyone could lend would be cool.
    (\__/)
    (")_(")
    I have a Worklog, but I have to take pictures as it's completely out of date now.
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
