Page 90 of 317 FirstFirst ... 408081828384858687888990919293949596979899100140190 ... LastLast
Results 891 to 900 of 3166
Thread: Lsx Void 3.0
  1. #891
    Variable Bitrate CARLOS_CET's Avatar
    Aug 2004
    NH
    Quote Originally Posted by Enforcer View Post
    From what I've heard about the music in your car, Format C: should suffice
    Ha Ha Ha.....very funny.
    Car PC Progress
    (>>>>>>>>>>>>---) 90%
    "Don't speak about it, be about it"
  2. #892
    Jul 2006
    New Convert
    LS
    I'm a recent convert from John's Digital Transparent 2.0. I needed to be able to configure the buttons the way I want and where I want. I have to say this version is awesome !! I love the the functionality that you've built into it. I have a question though:
    Can I disable the "Good Morning / Good Night" thing?
    Like everyone else can't wait to see 3.0 !!
    Thanks again!
  3. #893
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by montgomeryt View Post
    LS
    Thanks again!
    yes, its very easy to disable.
    ( i think ill put this in the options screens, its about a 50/50 of people who like , dislike it. I even turn it off myself)
    Open ExecTBL.ini found inside of the skins folder.
    Find and edit this line
    "LSONSKINSTART","ratecheck2||RUN;LSTOOLS\welcomeMS G\welcome.exe"
    The line will start with LSONSKINSTART, but may or may not be exactly like above. I cant remember if i changed it any. But the format is the same. You want to remove the section at the end of the line where it says to RUN;...\welcome.exe
    There is a how to that is step by step in this thread somewhere if you run into any trouble.
    beer replenishment fund
    mp3car live search
  4. #894
    Jul 2006
    Cool...
    So, in theory if I wanted to run my own scripts this is where I would put them ? Like run an autohotkey script that sets volume levels and so on...?
    The option would be nice but no big deal changing it.
    Thanks again
    Quote Originally Posted by liquid_smoke View Post
  5. #895
    Newbie Stray's Avatar
    Feb 2005
    Belgium
    I have 2 questions:
    1) Is there any way to let the time count down when playing songs?
    2) Where do I have to add "GOTOFIRST||SEARCHLIST" to search the playlist from the start?
    Stage 1:[||||||||||||||||||||] 100%
    Epia M10000, Lilliput 7' TS (modded), Teac DV28-SL, Globalsat BU-303, Maxtor 40GB 7200rpm, 512 MB pc3200, M1-ATX, Kenwood KDC-W6527SE
  6. #896
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    I've found that if you tap the counter it will switch form time count up to time count down.
    You can probably do it by setting this option in winamp (this is where the skin gets this info from, right?)
    Cheers
    BJ
    Leonardo Da Vinci
  7. #897
    Feb 2005
    Belgium
    Quote Originally Posted by greatwhite View Post
    Cheers
    BJ
    Not here. Moreover, when I tap the counter with the viz turned on, it changes the viz.
  8. #898
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by Stray View Post
    Change the label (i assume on the main menu, which do not change on tap) to "REMAININGTRACKTIME" with RRSkinEditor..
  9. #899
    Aug 2003
    Chicago
    this is intended.
    In the audio player u can see more detailed info on track time etc, as well as clicking the track time to reverse the count down.
    On the main menu, clicking the track time and track number on the far left and far right of the screen will change the visuals, if u have them on.
    I havnt given a lot of thought to these two items since i put them there ages ago.
    I think the track slider is a better indication as to how much of a track is left since its more visual than numbers and available on every screen.
    If youre hellbent on changing it though, it will require the skin editor and tab bit of patience as there is not just one main menu screen, but upwards of 11, and the way its setup is not how standard skins are setup. So for example, if you just edit the menu.skin file in the root of the skin folder, its possible to loose your changes by choosing a different menu layout in the skin options from within the skin.
    Not a difficult task, just something to be aware of before you start editing
    mp3car live search
  10. #900
    Aug 2003
    Chicago
    Thanks again
    yes, you can run your own scripts by adding commands to that line.
    There is also another line that will do the same thing,
    ONSKINSTART
    this line is a lot more important to the core functions of the skin and absolutely will not function if you screw it up.
    an even easier and more global way of running your own scripts or apps at RR launch is to create a command that loads your special tools etc inside of the ExecTBL.ini file that is in the ROOT of your RR install (not the skin). And inside of RRConfig.exe there is a option "Start Command to execute:" put your command here and it will work with any skin you happen to switch to in the future.
    mp3car live search
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
