Page 91 of 317 FirstFirst ... 4181828384858687888990919293949596979899100101141191 ... LastLast
Results 901 to 910 of 3166
Thread: Lsx Void 3.0
  1. #901
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by Stray View Post
    2) Where do I have to add "GOTOFIRST||SEARCHLIST" to search the playlist from the start?
    which screen do u want this on?
    beer replenishment fund
    mp3car live search
  2. #902
    Feb 2006
    Hi,
    Is there any planned support for FreePhone?
    Thanks.
  3. #903
    Newbie Stray's Avatar
    Feb 2005
    Belgium
    Quote Originally Posted by liquid_smoke View Post
    this is intended.
    In the audio player u can see more detailed info on track time etc, as well as clicking the track time to reverse the count down.
    On the main menu, clicking the track time and track number on the far left and far right of the screen will change the visuals, if u have them on.
    I havnt given a lot of thought to these two items since i put them there ages ago.
    I think the track slider is a better indication as to how much of a track is left since its more visual than numbers and available on every screen.
    If youre hellbent on changing it though, it will require the skin editor and tab bit of patience as there is not just one main menu screen, but upwards of 11, and the way its setup is not how standard skins are setup. So for example, if you just edit the menu.skin file in the root of the skin folder, its possible to loose your changes by choosing a different menu layout in the skin options from within the skin.
    Not a difficult task, just something to be aware of before you start editing
    Ok, thx. And how about:
    "Where do I have to add "GOTOFIRST||SEARCHLIST" to search the playlist from the start?"
    Stage 1:[||||||||||||||||||||] 100%
    Epia M10000, Lilliput 7' TS (modded), Teac DV28-SL, Globalsat BU-303, Maxtor 40GB 7200rpm, 512 MB pc3200, M1-ATX, Kenwood KDC-W6527SE
  4. #904
    Newbie Niob's Avatar
    May 2007
    Norway
    warning, im like haf fdrunk right now., hahs
    i dont know whats wrong wit ur systm, here is what yourscreen shot lshould look like.
    either there is som problem wi ur computer , its not showing any of the dingbat fonts.
    you can make a simple test ur self on any skin and change a font towingldings and it will not show. weird, i think us shold try to test on a compter with, normal computer.
    man idrunkkk
    I hawe the werry same issue on my computer. Screen looks the same. Also thested with that font test skin. And all looks the same.
    I run XP-SP2 All fonts installed and checked and tested.
    I can use webdings fonts (all of them) in notepad or other programs.
  5. #905
    May 2007
    Norway
    And then after looking at the posts again.. i tryed setting my computer from norwegian regional settings to English UK. And then the fonts showed correctly.
    So now the question iss.. how to make em work in Norwegian regional settings? So i can hawe my own regional settings (As this apply to a lot of other applications and programs i use in the car).
    And yeah.. forgot to tell you how wonderfull your work are. Truly an artist, and a man of knowing what a scin should feel like Thank you. Looking forward to be able to use it fulltime in my car
  6. #906
    Aug 2003
    Chicago
    I think this is more of a RR localization issue, than a skin issue. Im not really sure as there isnt any way for me to test localization as i only have English windows and english fonts. I know RR is supposed to "work" in other languages but im not sure what u have to do configure this.
    The fonts in the skin can easily be changed though, so your not stuck with english fonts if u dont want to use them. Find and open the the text file LSXCOLORS.txt found inside the skin folder. The first 2-3 lines are the fonts that the skin uses.
    Let me know if that makes any difference or not.
    mp3car live search
  7. #907
    May 2007
    Norway
    Ill give it a try. And se if i can get it to function for me with Norwegian regional.
    LSXVoid.
    For your information:
    I do not run a norwegian XP i run English XP. But put the "region" and keyboard layout to Norwegian. So this can be tested on your system by only changing the region. Keybord layout is not needed to be changed. I did this when i had some bigger issues with RR when i installed the norwegian XP version. So there is some issues there. But Englis version runs great with RR. So that whas an easy choise for my car.
  8. #908
    May 2007
    Norway
    Request:
    What about implementing FreeFhone to the skin? I hawe PhoCo upp and running. But i prefere to use FreeFhone actually. As it do not need the phone to be awailable when i boot up the PC for it to be detected at a later time. With PhoCo you need to hawe the phone awailable at boot or it wont find it later at all.. sux :P hehe
    Love to be able to start the music or video under conversation in phone. Greate for longer cals in the car or when the kids watch video in the back.
  9. #909
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by Niob View Post
    LSXVoid.
    hi!
    Since it was my old posts u was reffering to earlier I just thought I would say something....
    Running most skins or plugins in xp with another regional setting then english is really a PITA... I was having problems with Tripmeter plugin earlier and last it was the GatsoHunter plugin... The only solution that works for me every time is just to set the regional setting to english, and I havnt run into any other problems with it even though Im using it with the rest of the computer in swedish... I can still use the swedish special chars and so on without any problems... if u find another solution please post it!
    Swedish site for CarPC's
    http://www.bilpc.info
  10. #910
    May 2007
    Norway
    ill sure do so "kjære nabo" if i find the solution
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
