3.3 download (direct link)
3.301 update you must have 3.3 already
3.302 update you must have above two already, Fixes the RideRunner's custom list issue (direct link)
also note for anyone using the RR installer to install Road Runner, after you install you must delete the file ziplocator.dll or RR will crash and burn. This file should not be included with RR anymore.
http://liquidsmk.net/New%20Folder/capture.jpg
someone sent me these links video of the skin, since i havent found time myself to make some decent videos, ill post them here.
VIDEOS
LSXVOID 3.2
DOWNLOAD VOID 3.2
fix for audio player idle time out values (recommended update)
fix for preset button leaving audio in a muted state when switching presets.
fix for search function in audio browser
*enable FreeFone (this update should not be applied before the above updates)
note: there is no specific order any of the "fix" files above need to be applied, as they are all different files in each fix. They are however meant to be applied after you install the latest version of the skin. * except for FreeFone
DOWNLOAD VOID 3.2.5 update patch. This is NOT a full install, requires minimum VOID 3.2
extract the files into your EXISTING skin install and overwrite all files present. Most of your skin settings will not be affected, but the skin will default to the theme in the pic above. More info on the upate here
Dont have time to write up a proper release notes tonite, but there will more information on all the new features in the coming day, along with videos of the features. stay tuned!
SHORT NOTES:
Make sure you completely uninstall any previous version of LSX VOID as well and remove any settings from rr.ini related to this skin from any previous install.
http://liquidsmk.net/VOID3.0/splash.jpg
upcoming features:
LSXVOID 2.02 updated 1/12/2007 couple bug fixes
WARNING:
BEFORE YOU INSTALL THE SKIN: make sure you remove all settings related to ANY versions of LSXVOID from rr.ini. This is NOT optional.
HISTORY of previous releases of this skin. Old thread is just to big to continue,( 1300 post )
WHATS NEW:
updated main menus, with multiple layout/graphics options
high contrast daytime version
new audio player with many new features.
Font and color settings are stored in one file "LSXCOLORS.txt" found in skins folder
new cdrip screen
updated fm/xm/sirrus screens
intergrated settings for IGAUTOSW (iguidance auto switch)
new config screens with a lot more options
quick menu (click time to access) is now 2x wide and can be placed on left, right or center of screen.
mini mode when you click gps speed on top
New games and almost all are touch screen friendly.
Camera screen layout changes
multiple web screens based on content. See .NET button
time display on videoscreen inside of slider (by request)
Weather Forecast videos from google inside the weather screens. To change the city from Chicago, edit "LSXCOLORS.txt". At the end of the file you will see a bunch of cities listed. Change the first line in this section to the city you want, only the url should be editied.
Built in help system auto runs on first Run of skin and each run, until you turn it off. Also a tip of the day feature is available with additional tips etc. See "OPT" (options) button on main menu.
new updated PhoCo screens to match the rest of the skin.
ATT function now will save curent volume% before it drops the volume to 10% and restore original volume when off.
RSS traffic plugin support, button found on custom command screen 3
placeholders for google earth plugin and Mobile Emulator plugin
1 easter egg, can you find it ?
AUDIO PLAYER NEW FEATURES:
5 disk changer: Saves 5 preset files (m3u) and cycles between them, saves current track and song position for each preset.
Directory player: Skips through each root folder in your music library. If your music library is setup like this; Artist/Album/tracks. The Directory player will load a different Artist (and all there albums) on each click.
NewHits plugin intergration: scans your music library for newly coppied tracks within the time specified by you.
Ratings Plugin new features: added a button that cycles between each 1-5 star playlist.
Removed album art in the default audio player. An alternative audio player is available that has album art, but removes the Directory Player and NewHits intergration. Its found on page 3 of the customize screen commands.
New playlist (m3u) browser, supports save, load,rename and delete of .m3u files.
New Application Embeding system:
Click and Hold any of the customizeable buttons on the main screens>click MORE until you reach screen 3. Choose any of the FREE51-FREE55 buttons.
Click the EMPTY button and go through SETUP to change the application that launches and embeds for this new button. No hand editing of commands or ini files required.
watch the demo video above if you have problems or want to see it in action.
also, run RRConfig.exe and add .exe to the file type for audio for this feature to work
other small tweaks, graphics, fixes and extensive script work that are too long to list here.
Video of skin in action - courtesy of Hari-Bari
[media]http://www.youtube.com/watch?v=h8HwBGvEW3w[/media]
