Page 1 of 317 123456789101151101 ... LastLast
Results 1 to 10 of 3166
Thread: Lsx Void 3.0
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Arrow Lsx Void 3.0
    3.3 download (direct link)
    3.301 update you must have 3.3 already
    3.302 update you must have above two already, Fixes the RideRunner's custom list issue (direct link)
    also note for anyone using the RR installer to install Road Runner, after you install you must delete the file ziplocator.dll or RR will crash and burn. This file should not be included with RR anymore.
    someone sent me these links video of the skin, since i havent found time myself to make some decent videos, ill post them here.
    VIDEOS
    LSXVOID 3.2
    DOWNLOAD VOID 3.2
    fix for audio player idle time out values (recommended update)
    fix for preset button leaving audio in a muted state when switching presets.
    fix for search function in audio browser
    *enable FreeFone (this update should not be applied before the above updates)
    note: there is no specific order any of the "fix" files above need to be applied, as they are all different files in each fix. They are however meant to be applied after you install the latest version of the skin. * except for FreeFone
    DOWNLOAD VOID 3.2.5 update patch. This is NOT a full install, requires minimum VOID 3.2
    extract the files into your EXISTING skin install and overwrite all files present. Most of your skin settings will not be affected, but the skin will default to the theme in the pic above. More info on the upate here
    Dont have time to write up a proper release notes tonite, but there will more information on all the new features in the coming day, along with videos of the features. stay tuned!
    SHORT NOTES:
    Make sure you completely uninstall any previous version of LSX VOID as well and remove any settings from rr.ini related to this skin from any previous install.
    upcoming features:
    LSXVOID 2.02
    updated 1/12/2007 couple bug fixes
    WARNING:
    BEFORE YOU INSTALL THE SKIN: make sure you remove all settings related to ANY versions of LSXVOID from rr.ini. This is NOT optional.
    HISTORY of previous releases of this skin. Old thread is just to big to continue,( 1300 post )
    WHATS NEW:
    updated main menus, with multiple layout/graphics options
    high contrast daytime version
    new audio player with many new features.
    Font and color settings are stored in one file "LSXCOLORS.txt" found in skins folder
    new cdrip screen
    updated fm/xm/sirrus screens
    intergrated settings for IGAUTOSW (iguidance auto switch)
    new config screens with a lot more options
    quick menu (click time to access) is now 2x wide and can be placed on left, right or center of screen.
    mini mode when you click gps speed on top
    New games and almost all are touch screen friendly.
    Camera screen layout changes
    multiple web screens based on content. See .NET button
    time display on videoscreen inside of slider (by request)
    Weather Forecast videos from google inside the weather screens. To change the city from Chicago, edit "LSXCOLORS.txt". At the end of the file you will see a bunch of cities listed. Change the first line in this section to the city you want, only the url should be editied.
    Built in help system auto runs on first Run of skin and each run, until you turn it off. Also a tip of the day feature is available with additional tips etc. See "OPT" (options) button on main menu.
    new updated PhoCo screens to match the rest of the skin.
    ATT function now will save curent volume% before it drops the volume to 10% and restore original volume when off.
    RSS traffic plugin support, button found on custom command screen 3
    placeholders for google earth plugin and Mobile Emulator plugin
    1 easter egg, can you find it ?
    AUDIO PLAYER NEW FEATURES:
    5 disk changer: Saves 5 preset files (m3u) and cycles between them, saves current track and song position for each preset.
    Directory player: Skips through each root folder in your music library. If your music library is setup like this; Artist/Album/tracks. The Directory player will load a different Artist (and all there albums) on each click.
    NewHits plugin intergration: scans your music library for newly coppied tracks within the time specified by you.
    Ratings Plugin new features: added a button that cycles between each 1-5 star playlist.
    Removed album art in the default audio player. An alternative audio player is available that has album art, but removes the Directory Player and NewHits intergration. Its found on page 3 of the customize screen commands.
    New playlist (m3u) browser, supports save, load,rename and delete of .m3u files.
    New Application Embeding system:
    Click and Hold any of the customizeable buttons on the main screens>click MORE until you reach screen 3. Choose any of the FREE51-FREE55 buttons.
    Click the EMPTY button and go through SETUP to change the application that launches and embeds for this new button. No hand editing of commands or ini files required.
    watch the demo video above if you have problems or want to see it in action.
    also, run RRConfig.exe and add .exe to the file type for audio for this feature to work
    other small tweaks, graphics, fixes and extensive script work that are too long to list here.
    Video of skin in action - courtesy of Hari-Bari
    [media]http://www.youtube.com/watch?v=h8HwBGvEW3w[/media]
    beer replenishment fund
    mp3car live search
    Aug 2003
    Chicago
    Faq:
    Faq:
    FAQ HISTORY for previous releases of this skin
    1.) If anyone has any issues during setup or you forgot to remove all settings related to previous versions of this skin, in the root of your RR install you should find a file named "LSXVOID_DEFAULT_SETUP.exe". After you are certain all previous settings are removed from rr.ini run this file. Note: any custom changes to .skin files for the day version of the skin will be overwritten and all settings (for this skin) will be reset to the defaults. For reference and incase you want to manually add the settings to rr.ini by hand they are located in a file named "LSX_ADDTORR.INI.txt" also found in the root of your RR install or here incase you somehow lost the file.
    2.) Make sure you add .exe files as an audio file type in RRConfig.exe, otherwise when trying to embed an app using the built in embed setup (FREE buttons)
    you will not be able to see the .exe file to choose as the application to launch.
    3.) How do i make the visuals transparent like in the screenshots?
    Open RR.ini and add this line.
    AvsTransparent=TRUE
    In the same dir you should see a file named Screensaver.ini (the name is missleading)
    Open it and make sure the settings are like below
    AvsTransparent=True
    FadeOnIdle=False
    SecondsToFade=300
    FadeInterval=10
    DefaultOpacity=175
    MaxOpacity=255
    Turning on opacity from inside of winamp will give you a transparent visual, but it will still cover buttons in RR and you will not be able to click those buttons till u turn the visu off. What the directions above does is allow you to turn the visuals on, have them transparent and also the ability to still click the buttons under the visuals so you dont have to toggle them on/off to change the volume etc.
    Q. I have installed this skin but get a white bar like so.
    A. Install the lastest version of flash, make sure you do this from within Internet Explorer.
    mp3car live search
    Aug 2003
    Chicago
    Supported Applications
    APPLICATIONS:
    External applications that are presetup to work with the skin.
    note: all apps should installed to there default paths, dont change anything.
    SYSTEM MANAGER
    IF you dont have system manager installed, go here, install to the default path. Load the skin, click the right big grey arrow on the main menu, click SYSTEM button
    there are multiple links to the differnt versions of system manager (copytool) in that thread, the last 2 versions
    5.2 ver
    5.5 ver (has some reported issues)
    LSX VOID SKIN for system manager, sys man can only have ONE skin at a time, so you will have to overwrite the default skin with the lsxvoid version. BACKUP the default first if you plan to use it later.
    EDIT C:\Program Files\System-Manager\settings.ini and under the [GENERAL] section make the values look like below.
    [General]
    ResX=800
    ResY=407
    Top=51
    Left=0
    Enable Exit-Button=1
    CALENDAR
    Calendar support
    this is a rainlendar <---link) skin to match lsx void
    800x600 800x480
    These files go into the skin dir under rainlendar
    C:\Program Files\Rainlendar\Skins
    VISUALS
    vis used in screenshots
    PAINT
    http://www.ambientdesign.com
    instal to default path
    C:\Program Files\Ambient Design\ArtRage 2
    After install, open ArtRage and save a new file as default.ptg inside the same dir as the application. You may want to make the background pure black so it matches with the skin.
    SENSOR
    SpeedFanhttp://www.almico.com/speedfan.php
    EMU
    Mobile Emulator
    SYNC NOTES
    "NEW" "SHOW/HIDE" AND "SYNC" BUTTONS AT THE BOTTOM OF THE QUICK MENU (CLICK TIME)SYNC NOTESsticky not app that syncs the notes between multiple computers
    INSTALL TO DEFAULT PATH
    syncnotes
    mp3car live search
    Aug 2003
    Chicago
    Add On's
    Updates & Mods:
    will be some cool stuff here soon
    LS3.0 Logo clocks
    mp3car live search
    Sep 2005
    Mexico
    DAMN SWEET I just saw the video.. impressed what this 'skin' can achieve (I see it more like an addon for extra functions for RR
    Great job!
    Just hope it will run nice on my EPIA M1300.. the old version used to be a bit slow... did u changed that thing that u said on the previous thread? (i think it was something of the overlay)
    My current project
    Jetta 2000 MKIV
    SP13000/Xenarc 7"
    100GB / 512 RAM / GPS / Wi-Fi
    Mar 2006
    NY
    Can't wait! =)
    FLAC SnyperBob's Avatar
    Nov 2001
    Illinois
    Oh
    My
    Goodness!
    www.mobile-effects.com
    Free file hosting, picture gallery hosting for installs, PM me.
    Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
    May 2004
    Thank you! Can't wait to try.
    Jul 2005
    The only skin I run - you are incredible. Thank you x100
    1997 Mustang GTS "Jenna"
    VIA SP13000, 7" Xenarc TSV, 200GB, 'modified' M2-ATX, 1GB DDR400/3200, BU-353. RoadRunner + LSXVoid
    May 2004
    Quote Originally Posted by Miles View Post
    There are other skins????
  1. HD radio skin for LSX void 3 download
    By hugenius79 in forum RR Skins
    Last Post: 12-26-2008, 02:24 PM
  2. LSX Void Error
    By TeamRSX in forum RR Skins
    Last Post: 12-31-2007, 01:52 AM
  3. Lsx Void Error
    By michael2 in forum RR Skins
    Last Post: 08-15-2007, 10:55 PM
  4. StreetDeck for a 1955 Buick
    By aforget in forum DigitalMods (Scripts / API)
    Last Post: 07-29-2007, 02:01 PM
  5. LSX Void FAQ
    By Cali in forum Wiki Discussion Threads
    Last Post: 07-23-2007, 08:00 AM
