View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #1071
    Constant Bitrate morris_the_cat's Avatar
    Aug 2006
    Vancouver
    Wholy smokes! Now that you have made the text more prominent & showed the background I am using, the skin looks frikin amazing with the visual! Alright, I gotta change my visual from milkdrop to that one. Time to read the directions on that, but after the hockey game...
    Wholy smokes! I hope that wasn't your writing finger?!!
    2001 PT Cuiser
    VoomPC with 1.5Ghz C7
    M2 power supply
    in dash slim tray dvd drive
    DWW-750FM c/w 7" USB touchscreen,AM/FM, 4x45W amp
    See my install here
  2. #1072
    Constant Bitrate Mr_Civic's Avatar
    Nov 2006
    South Florida
    Quote Originally Posted by JohnWPB View Post
    As for the album art not changing on certain screens:
    RR has always been a little lazy about updating that. You can add a line somewhere in the skin that you want to make sure it is updated, when you go to that skin:
    /DISCARDABLE
    that line can go anywhere in a skin file on a line by itself. This means that RR will force itself to re-load the skin images, and any artwork ect on that skin whenever you go to it.
    Added that to the Audio_Full_Player skin after the first three lines and still doesn't get it to refresh. Do I need to add it to another skin?
    Alex
    Progress: 91% (Cosmetics) @ Stand Still...
    CarPC specs are BACK!! Edit yours today...
  3. #1073
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Quote Originally Posted by Ruffy View Post
    john seriously, take like a 4 month break!
    HUSH yo mouth
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  4. #1074
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Thanks Alot! I installed speed fan here to test it out myself on the desktop. It's hard to tell what the real temps are verses the phantom temps. I put the back of my hand up against the CPU fan, while monitoring the temperature on the screen. Well, I got a little to close! One of the fan blades caught my ring finger, and went up under the fingernail, and snapping one of the blades off of the fan! Talk about nosies and vibration! (This is a high speed fan on a Dual Core P4 processor).
    I immediately reached behind and pulled the power cord before the CPU cooked. It was then that I noticed I was bleeding like a stuck pig! The fan blade cut the end of the finger a little bit, before going pretty far up under the nail! yes.... *OUCH*! (Cant post a few of the choice words I said when it happened )
    I looked at the clock and saw that I had 40 minutes to make it across town during rush hour to get another fan, or it was no computer for me tonight!
    Well I got back, and had to take everything out of the case to remove the motherboard, as the mounting bracket goes on the back of the motherboard for the fan. I just got it all put back together, and came here to post about the ordeal. What a mess!
    Goes under the heading of "Suffering for your art".
  5. #1075
    Feb 2007
    Croydon UK
    Enforcers Traffic cams
    at the moment if i tap traffic button in Programs Skin,i get traffic infomation for the usa,when press and hold get traffic cams.
    is there any way i can have traffic cams as default button so on tap of button i get traffic cams instead of usa traffic info.
  6. #1076
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by Mr_Civic View Post
    the /Discardable line in a skin, simply removes the images from that skin from memory, when you leave the skin. Thus forcing RR to reload all images for that skin when you come back to it. Is you art not updating when the song changes? I have not had that problem here, and not sure what it could be if that is the case.
    Quote Originally Posted by Capri28 View Post
    Ok, for you people on the other side of the pond
    Open the "Programs.skin" in notepad, and find this line:
    Code:
    B37,404,270,391,134,"Load;Traffic.skin",@TrafficCams@
    Replace the entire line with:
    Code:
    B37,404,270,391,134,"TrafficCams"
    My Fiero Build Thread
  7. #1077
    Low Bitrate rcubed3r's Avatar
    Feb 2007
    Salisbury, NC
    I hate to sound like an idiot, but my car PC is up and running very good now, and I am tweaking.
    I am looking thru the help file and wanting to add the spectrum analyzer. The help file asks me to 'locate the "Spectrum Analyzer" folder in the location you unzipped the DigitalFX Skin to'. I didn't unzip anything. I have looked in the folder created in the skins folder, and the spectrum analyzer folder is not there. I also looked for the theme.ini file for iG, but it is not there as well. I did a search on my hard drive and could not find them either.
    I know there is a simple solution, I just can't find it!
    Any help is appreciated!!
    Also- on a side note- How can I change the silly car icon on iG UMPC to the arrow for location? It is hard to tell which way the car is going on North-Up maps.
    Thanx,
    Ron
  8. #1078
    Aug 2006
    Vancouver
    Quote Originally Posted by rcubed3r View Post
    I beleive it is in the "DigitalFX_Winamp_AVS" folder now, within the skin directory.
    2001 PT Cuiser
    M2 power supply
    See my install here
  9. #1079
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Update Released 04/26/2006 5:10PM EST
    Thanx,
    Ron
    You are not the idiot, I am! hahaha I forgot to package some of the helper files and such with the new installer program.
    You can download the new version, and the help file has been updated with updated instructions, and screen captures to make setting it up a breeze.
    This adds the visualizations to the main menu, and allows you to change the visualizations from within the skin.
    Also the Audio screens have been rearranged, so when you click on the MUSIC button, you go directly to the player now, and not the browser. Check the help file the installer puts on your desktop, under revision history for all the additions an fixes.
  10. #1080
    Constant Bitrate Volsfan's Avatar
    Jan 2006
    Kingsport, TN
    YEAH!!
    I know that the large red font is reserved for you, but this is just great.
    I have been searching and reading, all 2 million pages of this thread, but can't find. Are the animated weather GIF's working, or is that in the works?
    I have tried to do everything that I know of, but still get the gifs from like early April when it was snowing in the Great Lakes area
    Tennessee Vols Fan
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
