View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #1091
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by GizmoQ View Post
    Just out of curiosity, John what font and size did you use for the buttons on that screen (I need to change some of the text on the buttons for my personal destinator implementation)?
    Sorry, missed the question:
    Not sure what screen or text you are refering to. The font is Sergoe Media Center. The easiest way I have found to match a font size, is, in Photoshop, to type the same label over the top of the existing text. Then go to edit, Transform, scale, and adjust it to match the size of the text behind it.
    My Fiero Build Thread
  2. #1092
    Constant Bitrate Mr_Civic's Avatar
    Nov 2006
    South Florida
    Quote Originally Posted by JohnWPB View Post
    the /Discardable line in a skin, simply removes the images from that skin from memory, when you leave the skin. Thus forcing RR to reload all images for that skin when you come back to it. Is you art not updating when the song changes? I have not had that problem here, and not sure what it could be if that is the case.
    John.
    It does but if I select a song from the playlist manually, this is when it does not update (unless the previous song had no album art).
    Adding /DISCARDABLE, it does seem to correct the error most of the time (90%); can't understand why sometimes it doesn't do it. Nevertheless, I can live with that.
    However, now whenever I press the GPS, it hides RR and the taskbar and leaves only the iGuidance open at the spot where it would generally be displayed. I couldn't open the tasklist because didn't have a mouse/keyboard connected to it but the music was still playing. I had to reset the system. In fact, this also happened when I clicked on the EQ button. Can you reproduce this error? If not, I guess I would have to take out /DISCARDABLE as I'd rather have my GPS working on that screen then refreshing album art (on manual selections).
    Alex
    Progress: 91% (Cosmetics) @ Stand Still...
    CarPC specs are BACK!! Edit yours today...
  3. #1093
    Dec 2006
    What a coincidence, I just added the exact same thing last weekend. Didn't think to request it as a skin change. Also I added city & state to top of Audio-GPS.
    I vote against this change. I like having as much screen real estate as possible for the map.
  4. #1094
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Sorry if I missed it in this thread...getting kinda big.
    When I am in Gps, if I hit ANY buttons on the right (ie: gas) IG disappears and all buttons become inop. I actually have to reboot.
    It was working fine, I just wish I knew when this started.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  5. #1095
    Mar 2007
    Nashua, NH
    Quote Originally Posted by muldrick View Post
    I am seeing this as well. I was away for a few days and have missed a few pages. I scanned for this problem but didn't see it.
    I found that you don't need to reboot (assuming you have a keyboard). Just hit escape and it returns to normal.
    For me it started with v2.11 downloaded 4/25/07.
  6. #1096
    Mar 2007
    Nashua, NH
    Update to my last post: It is only the "Route to" and "Auto Config" buttons that don't appear to be working. I am calling the top right button the "Route to" button.
  7. #1097
    Constant Bitrate morris_the_cat's Avatar
    Aug 2006
    Vancouver
    Hi John,
    Loving the updates from yesterday, but I sure found a really interesting bug this morning. Well, it is kinda a bug, because I know you aren't officially supporting RREarth, but anyway here goes. I don't have satellite radio so I use the skin editor to remap the satellite radio to RREarth (ie: change command "XM">"GE_start"). Anyway, when I leave RREarth and go back to the main menue, lo & behold, the entire upper part of the main screen where you recently placed the transparent spectrum analyser is a really wide and short google earth window! No song information or anything else is visible in that window. While you don't support RREarth, you may be interested in knowing this for future skin changes in case u do end up implementing it later. I think I probably have to either revert back to the previous main menu skin or else figure out a way to change that myself (for me, a nearly impossible task!). I wish I could get a screen capture of this for you, but I don't have a keyboard hooked up to my carpc & thus no prtscn button.
    2001 PT Cuiser
    VoomPC with 1.5Ghz C7
    M2 power supply
    in dash slim tray dvd drive
    DWW-750FM c/w 7" USB touchscreen,AM/FM, 4x45W amp
    See my install here
  8. #1098
    Oct 2006
    CT
    John,
    I had an idea: The player skin, when you dont have an album art, it says No Album Art Available, Instead when there is no Album art, i think it would be nice to place an image there, maybe a Music tone image, or something default to make it look nice.
    When i have the visualizer on with low transparency, would be nice to have an image there, if its not too much work.
  9. #1099
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by klundy View Post
    Well too bad! I added it! hahaha! Just kidding of course, that bar was tall enough as it was to fit the song info and the city, County & zip. The bar was too short to fit the state in as well... but if you do not know what state you are in, you shouldn't be behind the wheel in the first place
    Quote Originally Posted by meisner View Post
    Sorry, That one is my fault. I failed to change the image names that those to skins use, or failed to make the PNG's all together. It will be fixed in the next release.
    Quote Originally Posted by morris_the_cat View Post
    Quote Originally Posted by Zeeshan0581 View Post
    John,
    I can do that quite easily, I will just put a nice looking CD jewel case or something there instead.
  10. #1100
    Low Bitrate jjnit's Avatar
    Feb 2007
    Hmm - been on the road out of town and found a few more things that might smooth out this skin. Not that it needs it
    Guess I owe more to your beer fund too - my first round was probably barely enough to get you a buzz lol...
    OK:
    Radio skin:
    #1 - The mute button acts wierd. It works, but the muted up-state looks like the unmuted up-state. Rollover/down states are correct, but as you can see in the attached image, (it's currently muted) I can't tell it's muted.
    #2, #3 - Anyway to make one of the 2 ways to change channels a page up/dn instead? See diagram - maybe make #2 the page up/dn and #3 leave as channel up/dn?
    Thanks John - Looks great!!!
    Edit: dammit, pic won't upload.
    Edit again - ok here it is...
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
