View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Thread: Digital FX 2.0 Transparent Released
  1. #1121
    Newbie vidason's Avatar
    Apr 2006
    long island ny
    thank you i will try that as soon as i can.
  2. #1122
    Feb 2007
    Croydon UK
    Change camera program
    i would like to change the webcam feature to another program.
    the resides in the road runner : C:\Program Files\Road Runner\DaulCapture\Start Both Captures.bat
    i know i need to change the line in the programs skin, but to what is my question.
  3. #1123
    Apr 2006
    long island ny
    rr locking up
    Quote Originally Posted by Capri28 View Post
    that came with the skin, i added to rr.ini then everything went pear shape so i tool it back out of rr.ini
    code was : localdatacaptureinterval=1
    i removed the code and i still have the problem.
    in ig3.0 if i hit the auto config button in gps skin rr locks up
    i can get out of gps by using esc on kb any answers
  4. #1124
    Constant Bitrate Bump's Avatar
    Nov 2004
    Chambersburg, PA
    Quote Originally Posted by vidason View Post
    read post 1100.
    wait for next release
  5. #1125
    Nov 2004
    Chambersburg, PA
    that code is for the auto update of the City,state names from your GPS.
    if you replace the 1 with a 0 , it will not update.
    If your computer is slow just use a higher number.
    the info on that code in on you desktop. when you installed the skin.
  6. #1126
    Feb 2007
    Croydon UK
    i tryed that
    changed the time, the thing is as soon as i add the line to rr.ini everything locks up when i go to gps. i'm not using iguidance and i thought i was connected some how so i took the line out and everything is hunky doorey now.
  7. #1127
    Nov 2004
    Chambersburg, PA
    Have you got the new version of RR?
    that code only works with the new version.
    version should be " April 12 2007 " (4/12/2007)
    It looks like you have 1.0 version of the skin. if so ,you would not need the localdatacaptureinterval=1 code. there is nothing in the skin that is using it.
    that is only for 2.0 version skin
    edit:
    If that code was in your rr.ini . then you installed 2.0 version. and added all the code from 2.0 to the rr.ini.
    did you add the other optional codes too? if you did you might need to remove them too. they were for the 2.0 . But, I'm not 100% sure about that.
  8. #1128
    Constant Bitrate megagoo's Avatar
    Oct 2004
    what is "iGuidance 3.0 UMPC Patch" on john's download site? i searched this thread and nothing came up
    also do i have to do anything special to update and keep my RR settings?
  9. #1129
    Mar 2007
    Nashua, NH
    ^^^ Along with that question is do we need to uninstall DFX2 before installing a newer version? Or can we install over the old...which is what I've been doing.
  10. #1130
    Raw Wave lostreception's Avatar
    NY
    Quote Originally Posted by megagoo View Post
    it is a patch i made and john modded to make iguidance look like the dfx skin as well as adding the funtionality that inav has left out (to navigate by coordinates)
    for more info search on "ig3 coordinates"
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
