You have to change the settings in the RRConfig utility so use streets and Trips.
EDIT:
Actually the easiest way to get this to work for you is to:
Open the Exectb.ini file in the DigitalFX Skin folder in notepad
Add the following line anywhere to that file and save it.
Run RR and when you press the GPS button it should work for you.Code:"GPS","LOAD;StreetsTrips.skin||RUN;C:\Program Files\Microsoft Streets and Trips\Streets.exe;Map - Microsoft Streets & Trips"
Here is a screen Capture of it running in the skin:
LinkBack URL
About LinkBacks
LOL!
