View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Page 13 of 376 FirstFirst ... 3456789101112131415161718192021222363113 ... LastLast
Results 121 to 130 of 3760
Thread: Digital FX 2.0 Transparent Released
  1. #121
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Help File.
    EDIT: Updated help file is now in the main .zip file
    Sorry about that
    My Fiero Build Thread
  2. #122
    Jul 2006
    Hey John!
    Awesome changes - I just downloaded the latest version and the new help file. Did you hide the psd's somewhere? I looked on the first page and in the help file and you didn't mention them.
  3. #123
    Constant Bitrate DeadlyAP1's Avatar
    Aug 2005
    MA
    John, one thing I noticed on the BlueDevil skin and now on the digital series, is that when you go to the "music" function, you are taken straight to the browser. Is this done for a reason? Personaly, I would rather go straight to the "player" skin instead of having to hit the button at the bottom of the browser skin to get there. Once my play;ist is loaded, I generaly don't need the browser skin unless I want to change. Maybe it's just me.
  4. #124
    Sep 2006
    Sabattus, ME
    Thanks for clearing up the issues with that company John.
    CarPuter: 900Mhz P3 with 256 MB Mem, 160 Gig HD (Thanks kbreeden), Iguidance 3.0 GPS, Logitech PS2 keyboard, Bluetooth, WIFI.
    Powered By Road Runner & DigitalFX Skin and Playlist Conveter
  5. #125
    Mar 2006
    i had a profound idea. Is there a way we can implement an easy way to switch navigation software via skin? So if we are using IG3 and wanted to use mappoint for the poi's we could just switch it in the skin.
    Just a thought.
    Cars:
    2001 Lexus es300 carpc Complete!Lexus es300 thread
    CarPC: Hp laptop, Lilliput 7'' ts, ig3, bluedevil skin, hauppage tv tuner, bu-353, griffin powermate, backup camera, ps2, headrest monitors, nightvision camera.
    2006 Lexus es330 next project.
  6. #126
    Jun 2002
    Virginia
    Speed Fan Configuration
    Boy, setting up the Speedfan configuration is a little tricky. One suggestion that I would make, John, is that you indicate in speedfan.skin which line is for which setting. I had to go through the X/Y coordinates to figure out what buttons I needed to reset.
    I also have a couple of questions:
    1. The diagnostic screen is showing that I have total memory of 479, that 144 is free and that 62% is remaining. That doesn't seem right since 144/479 = 30% remaining. Am I missing something?
    2. Speedfan shows me five different temps, temp1, temp2, temp3, temp4 and HD1. Obviously, I know that HD1 is the temp of the harddrive, but how do I figure out what the others are for? Is it safe to assume that the highest one is the chip temp?
  7. #127
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Questions and answers
    Quote Originally Posted by SangreDeThor View Post
    Ummm your welcome I guess
    Quote Originally Posted by DeadlyAP1 View Post
    This is kinda a personal preference really. I am open to suggestions on what people think though.
    Quote Originally Posted by spiike View Post
    i had a profound idea. Is there a way we can implement an easy way to switch navigation software via skin? So if we are using IG3 and wanted to use mappoint for the poi's we could just switch it in the skin. Just a thought.
    If you go into the RRConfiguration program, you can choose GPS "Menu". This will pop up an on screen menu to choose from the GPS program that you want to use. You can have 4 GPS programs (or more) installed and have access to all of them. You will just have to edit the button codes on the "GPS_Menu.skin" file.
    Quote Originally Posted by kbreeden View Post
    I agree 100% that it is definitely hard to set up, no doubt about it. Unfortunately there is no way to put comments in the skin file right now, as the editor removes them when the skin is saved.
    To get my temperatures, I had to run drefrag on my Hard Drives, to watch the temp go up a little bit to know what HD was what
    As the the other temperatures, the highest one is usually the CPU, and the next highhest is usually the case temperature. It will vary from system to system, but this is a good rule of thumb.
    I wish I could make the set up of this easier, but there really is no way that I know of right now. The bright side is, once it is done, you don't have to do it again on that computer.
  8. #128
    Jun 2002
    Virginia
    I don't know if this messes you up or not, but since you can't make comments in the speedfan.skin file, maybe you can rearrange the code lines so it's easier to tell what line goes to what button. For example, maybe left to right, top to bottom as follows:
    Line 1: CPU Temp
    Line 2: CPU Fan
    Line 3: CPU Load
    Line 4: Case Temp
    Line 5: HD1 Temp
    Line 6: HD2 Temp
    and so on. A big part of the effort for me was trying to figure out which lines went to which buttons so I could change the appropriate codes.
    Also, do you have any thoughts on my first question in post 128?
  9. #129
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Sorry I missed that question.... You want me to do math now?!
    I will look into it and see if I can figure what went wrong....
  10. #130
    Jun 2002
    Virginia
    Math is 3x your normal rate, right?
    Also, you're exactly right that the diagnostics are really neat once set up. Nice work on the skin!
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
