Hi all...... when i start digitalfx i have this screen:
Any ideas??
MapPoint
Destinator
Streets & Trips
Other
Any ideas??
Did you add the code to RR.ini that was on you desktop?
you have to add this to your RR.ini.
picspath=C:\Program Files\Road Runner\skins\DigitalFX 2.0\Backgrounds
fastmode=-1
localdatacaptureinterval=10
in the localdatacaptureinterval=10 command. you can replace 10 with any amount of Minute you want the Weather to reload. 0=Manual reloading: 1-30 mins.
Do one more thing before you re-download and re-install: make sure your shorcut to RR is pointing to the right roadrunner.exe.
I had renamed the old exe to roadrunnerbeforedfx.exe then copied the one from the destop to the RR folder but still got the black bar; for some reason i checked the shortcut and it was still using roadrunnerbeforedfx.exe![]()
I moved the old file out of the rr directory and remapped the shortcut to use the new rr.exe and PUFF! all was well..
Try that and if not, reinstall..
Where i can download Roadrunner last version clean, not only the roadrunner.exe..... all suite with rr.ini, and all files need to have roadrunner clean?
